Manufacturing Solutions
Solid Meshing Wizard
Previous topic Next topic Expand/collapse all hidden text
The Solid Meshing Wizard is used to create solid (3D) mesh model data decks for injection molding analysis starting from solids. It enables meshing of solids using three different techniques:
•Solid Map
•Volume Tetmesh
•CFD Tetmesh (tetrahedral mesh with boundary layer)
Mesh created in each solid is placed in a component collector with the name <Comp Name>_<3D Mesh type>#n, where <3DMeshtype> is either of the solidmap, tetmesh or BLmesh and n is an integer represents the ID of the respective solid in the model.
hmtoggle_plus1greyStep 1: Select Components to be Meshed
Click on the Solid Meshing Wizard macro to open the following dialog. This dialog is used to select the components for meshing. Select a component and add it to the respective meshing group. For example, select Sprue1 and click Solidmap to add it to the Meshed by Solidmap folder.
solid_meshing_wiz_01
After selecting the components, click on Next to proceed.
hmtoggle_plus1greyStep 2: Element Size and Meshing Options Selection
This panel shows three tabs, once corresponding to each meshing method. Solid Map and Tetra Mesh tabs list the selected components and respective solids with their IDs. It also shows the recommended element size for each solid as shown in the below image. This size can be changed by the user.
solid_meshing_wiz_02
The CFD Mesh tab displays additional meshing parameters relevant to creating boundary layer mesh in addition to the element size, as shown in the below image. Please refer to the help on CFD BL meshing.
solid_meshing_wiz_03
This tab also allows you to select and specify the surfaces to be considered as inlet/outlet/symmetry surfaces for the purpose of creating a boundary layer mesh. Refer to the CFD mesh help for better understanding of the above mesh parameters.
Mesh will complete by clicking on the Mesh button.
