Manufacturing Solutions
Working with Surfaces
The Surfaces group of the Utility menu enables you to perform geometry cleanup and extract midsurfaces.
•The Cleanup button opens the Edge Edit subpanel, from which you can clean surfaces, trim surfaces, add or remove fixed points, etc.
•Use the Midsurface tool to extract a midsurface from a selected surface.
See Also:
Moldflow Utility Menu
