/DT/Eltyp/Keyword3/Iflag
Engine Keyword Element time step control.
If using /DT/BRICK/CST/1, insert the next line:
COL_min Vdef_min
If using /DT/BRICK/DEL/1, insert the next line:
COL_min Vdef_min ASP_max Vdef_maxDefinition
| Eltyp | Entity selection:
| Keyword3 | Time step control type.
1
If Keyword3 is not specified, that is, /DT/Eltyp, then the default Keyword3 option for each Eltyp is used. 2 |
| Scale factor on critical
time step for the option defined by
Eltyp. Default = 0.9 |
| Minimum time step | ||
| Iflag | Number of additional
(optional) cards. Only used for /DT/BRICK/CST/1
or /DT/BRICK/DEL/1.
| COL_min | Minimum collapse ratio to
switch solid element to small strain formulation (to keep constant
time step) or to deleted solid element. If Ndir ≥
1, the element is deleted and SPH elements are
activated. 6
7 Default = 0 |
| Vdef_min | Minimum volume ratio
(V/Vo) to switch solid element to small strain formulation (to keep
constant time step) or to deleted solid element. If
Ndir ≥ 1, the element is
deleted and SPH elements are activated. 6
7
Default = 0 |
| ASP_max | Maximum aspect ratio to
activated. 7
Used only if different from 0. Default = 0 |
| Vdef_max | Maximum volume ratio
(V/Vo) to deleted solid element. If Ndir ≥
activated. 7 Used only if different from 0. Default = 0 |
- For all
Keyword3 options, the time step control will be activated
when the time step of the element controlling the time step of the simulation
becomes less than:
- The table below lists
the different available combinations of Eltyp and
Keyword3. The default options are used when
Keyword3 is not specified such as
/DT/BRICK or /DT/SHELL.
STOP DEL CST QUAD Default Optional BRICK Default Optional Optional SHELL, SH_3N Optional Default Optional BEAM, TRUSS, SPRING Optional Optional - For each Eltyp value, only one /DT/Eltyp/Keyword3 option can be used in a simulation.
- /DT/Eltyp/Keyword3 can be used with /DT/NODA/Keyword3.
- /DT/BRICK/CST is only active when Ismstr=2 or 12 is defined in /PROP/SOLID. It is compatible with /TETRA4 with Itetra=0, /TETRA10, and /BRICK solid elements with Isolid=1, 2, 14, 17, or 24.
- With
/DT/BRICK/CST/1, solid elements will be switched to small
strain formulation when criteria for COL_min or
Vdef_min is reached.
- COL_min uses the same collapse ratio calculation as in HyperMesh element quality check.
- Elements failing the COL_min criteria will be switched to the small strain formulation at the beginning or during a simulation.
- Vdef_min can be used to switch highly deformed or compressed elements to the small strain formulation during the simulation thus avoiding negative volume issues that can arise.
- With
/DT/BRICK/DEL/1, solid elements will be deleted, or
switched to SPH elements if Ndir ≥ 1 in the
solid property, when criteria COL_min,
Vdef_min, ASP_max or
Vdef_max is reached.
- COL_min and ASP_max use the same collapse ratio and very similar aspect ratio calculation as in HyperMesh element quality check. For thickshell, thickness direction is not taken into account, then aspect ratio 2D and collapse ratio 2D (L_min/L_max) are used to compute COL_min and ASP_max.
- Elements failing the COL_min or ASP_max criteria will be used to delete or switch to SPH elements (if Ndir ≥ 1 in the solid property) at the beginning or during a simulation.
- Vdef_min or Vdef_max can be used to delete or switch to SPH elements (if Ndir ≥ 1 in the solid property) when the solid element is highly deformed.
- A more conservative and thus lower time step calculation for shell elements can be activated by using, /DT1/SHELL.
- A more conservative and thus lower time step calculation for solid elements can be activated by using, /DT1/BRICK.
