Initialize, Verify and Finalize
The workflow in some user options may require initialization, verify during the run and finalize tasks in the Engine.
Those cannot be done in the computational routines. Some possible usages are either
specific license management for user option vendors, specific I/O handling.
- Initialization is accomplished before the time step loop.
- Check/verification is accomplished during the time step loop / Enables to force Radioss to exit properly
- Finalization is accomplished at the end, before Radioss exits
Important: The “
#ifdef
” and
“!DEC$
” pre-compilation directives are mandatory for
Windows compatibility. Do not remove them; otherwise, the routine will not be
found by Radioss Engine.Initialization
CALL ENGINE_USER_INITIALIZE( NSPMD, NTHREAD, MY_RANK)
#ifdef _WIN64
!DEC$ ATTRIBUTES DLLEXPORT, DECORATE, ALIAS : "ENGINE_USER_INITIALIZE" :: ENGINE_USER_INITIALIZE
!DEC$ ATTRIBUTES REFERENCE :: NSPMD, NTHREAD,MY_RANK
#endif
Where,
LINE
- Character string with the message.
NSPMD
- Number of MPI domains in the Radioss job.
NTHREAD
- Number of SMP domains in the Radioss job.
MY_RANK
- Domain Number of MPI process.
Checks/Verification During Run
CALL ENGINE_USER_CHECK(MY_RANK,TSTOP,NCYCLE,TT,MSTOP)
#ifdef _WIN64
!DEC$ ATTRIBUTES DLLEXPORT, DECORATE, ALIAS : "ENGINE_USER_CHECK" :: ENGINE_USER_CHECK
!DEC$ ATTRIBUTES REFERENCE :: MY_RANK,TSTOP,NCYCLE,TT,MSTOP
#endif
Where,
LINE
MY_RANK
MY_RANK
takes the values from 0 toNSPMD
-1.TSTOP
- Final simulation time.
NCYCLE
- Current explicit cycle number.
TT
- Current simulation time.
MSTOP
- Output value: if
MSTOP
> 0, Radioss will terminate with restart writing. Refer to Comment 1.
Finalization
CALL ENGINE_USER_FINALIZE(MY_RANK)
#ifdef _WIN64
!DEC$ ATTRIBUTES DLLEXPORT, DECORATE, ALIAS : "ENGINE_USER_FINALIZE" :: ENGINE_USER_FINALIZE
#endif
Where,
LINE
MY_RANK
MY_RANK
-1.
MSTOP
must always be set as return value. WhenMSTOP
is greater than zero, Radioss will terminate by writing a restart file and eventually a last animation file.
