Material Compatibility
Block Format Keyword The following tables list the compatibility options for each of the material laws.
Shell Elements
Law Name SHELL Shell Property
Type 1 Type 9 Type 10 Type 11 Type 16 Type 17 Type 19 Type 51 PCOMPP
/MAT/PLAS_PREDEF
/MAT/LAW0 (VOID)
/MAT/LAW1 (ELAST)
/MAT/LAW2 (PLAS_JOHNS)
/MAT/PLAS_ZERIL
/MAT/LAW3 (HYDPLA)
/MAT/LAW4 (HYD_JCOOK)
/MAT/LAW5 (JWL)
/MAT/LAW6 (HYDRO or HYD_VISC)
/MAT/K-EPS
/MAT/LAW10 (DPRAG1)
/MAT/LAW11 (BOUND)
/MAT/B-K-EPS
/MAT/LAW12 (3D_COMP)
/MAT/LAW14 (COMPSO)
/MAT/LAW15 (CHANG)
/MAT/LAW16 (GRAY)
/MAT/LAW18 (THERM)
/MAT/LAW19 (FABRI)
/MAT/LAW20 (BIMAT)
/MAT/LAW21 (DPRAG)
/MAT/LAW22 (DAMA)
/MAT/LAW23 (PLAS_DAMA)
/MAT/LAW24 (CONC)
/MAT/LAW25 (COMPSH)
/MAT/LAW25 (COMPSH) (Tsai-Wu)
SESAM
/MAT/LAW27 (PLAS_BRIT)
/MAT/LAW28 (HONEYCOMB)
USER1
USER2
USER3
/MAT/LAW32 (HILL)
/MAT/LAW33 (FOAM_PLAS)
/MAT/LAW34 (BOLTZMAN)
/MAT/LAW35 (FOAM_VISC)
/MAT/LAW36 (PLAS_TAB)
/MAT/LAW37 (BIPHAS)
/MAT/LAW38 (VISC_TAB)
/MAT/LAW40 (KELVINMAX)
/MAT/LAW41 (LEE_TARVER)
/MAT/LAW42 (OGDEN)
/MAT/LAW43 (HILL_TAB)
/MAT/LAW44 (COWPER)
/MAT/LAW46 (LES_FLUID)
/MAT/LAW48 (ZHAO)
/MAT/LAW49 (STEINB)
/MAT/LAW50 (VISC_HONEY)
/MAT/LAW51 (MULTIMAT)
/MAT/LAW52 (GURSON)
/MAT/LAW53 (TSAI_TAB)
/MAT/LAW54 (PREDIT)
/MAT/LAW57 (BARLAT3)
/MAT/LAW58 (FABR_A)
/MAT/LAW59 (CONNECT)
/MAT/LAW60 (PLAS_T3)
/MAT/LAW62 (VISC_HYP)
/MAT/LAW63 (HANSEL)
/MAT/LAW64 (UGINE_ALZ)
/MAT/LAW65 (ELASTOMER)
/MAT/LAW66
/MAT/LAW68 (COSSER)
/MAT/LAW69
/MAT/LAW70 (FOAM_TAB)
/MAT/LAW71
/MAT/LAW72 (HILL_MMC)
/MAT/LAW73
/MAT/LAW74
/MAT/LAW75 (POROUS)
/MAT/LAW76 (SAMP)
/MAT/LAW77
/MAT/LAW78
/MAT/LAW79 (JOHN_HOLM)
/MAT/LAW80
/MAT/LAW81
/MAT/LAW82
/MAT/LAW83
/MAT/LAW84
/MAT/LAW87 (BARLAT2000)
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW93 (ORTH_HILL) or (CONVERSE)
/MAT/LAW94 (YEOH)
/MAT/LAW95 (BERGSTROM_BOYCE)
/MAT/LAW97 (JWLB)
/MAT/LAW100 (MNF)
/MAT/LAW102 (DPRAG2)
/MAT/LAW103 (HENSEL-SPITTEL)
/MAT/LAW104 (JOHNS_VOCE_DRUCKER)
/MAT/LAW106 (JCOOK_ALM)
/MAT/LAW108 (SPR_GENE)
/MAT/LAW109
/MAT/LAW110 (VEGTER)
/MAT/LAW111
/MAT/LAW112 (PAPER or XIA)
/MAT/LAW113 (SPR_BEAM)
/MAT/LAW114 (SPR_SEATBELT)
/MAT/LAW115 (DESHFLECK)
/MAT/LAW116
/MAT/LAW117
/MAT/LAW119 (SH_SEATBELT)
/MAT/LAW120 (TAPO)
/MAT/LAW121 (PLAS_RATE)
/MAT/LAW122 (MODIFIED_LADEVEZE)
/MAT/LAW124 (CDPM2)
/MAT/LAW151 (MULTIFLUID)
/MAT/LAW200 (MDS)
/MAT/USERij
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
Solids
Law Name Elements Properties
Brick Tetra Thick Shell Type 6 Type 14 Type 20 Type 21 Type 22 Type 43
2D TRIA 2D QUAD 8 node 20 node 4 node 10 node 6 & 8 node 16 node
/MAT/PLAS_PREDEF
/MAT/LAW0 (VOID)
/MAT/LAW1 (ELAST)
/MAT/PLAS_ZERIL
/MAT/LAW3 (HYDPLA)
/MAT/LAW5 (JWL)
/MAT/K-EPS
/MAT/LAW10 (DPRAG1)
/MAT/LAW11 (BOUND)
/MAT/B-K-EPS
/MAT/LAW14 (COMPSO)
/MAT/LAW15 (CHANG)
/MAT/LAW16 (GRAY)
/MAT/LAW18 (THERM)
/MAT/LAW19 (FABRI)
/MAT/LAW20 (BIMAT)
/MAT/LAW21 (DPRAG)
/MAT/LAW22 (DAMA)
/MAT/LAW24 (CONC)
/MAT/LAW25 (COMPSH)
SESAM
USER1
USER2
USER3
/MAT/LAW32 (HILL)
/MAT/LAW37 (BIPHAS)
/MAT/LAW42 (OGDEN)
/MAT/LAW44 (COWPER)
/MAT/LAW48 (ZHAO)
/MAT/LAW49 (STEINB)
/MAT/LAW52 (GURSON)
/MAT/LAW54 (PREDIT)
/MAT/LAW58 (FABR_A)
/MAT/LAW63 (HANSEL)
/MAT/LAW66
/MAT/LAW68 (COSSER)
/MAT/LAW69
/MAT/LAW71
/MAT/LAW73
/MAT/LAW74
/MAT/LAW75 (POROUS)
/MAT/LAW76 (SAMP)
/MAT/LAW77
/MAT/LAW78
/MAT/LAW80
/MAT/LAW81
/MAT/LAW82
/MAT/LAW83
/MAT/LAW84
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW94 (YEOH)
/MAT/LAW97 (JWLB)
/MAT/LAW100 (MNF)
/MAT/LAW101
/MAT/LAW109
/MAT/LAW111
/MAT/LAW116
/MAT/LAW117
/MAT/LAW120 (TAPO)
/MAT/LAW124 (CDPM2)
/MAT/LAW200 (MDS)
/MAT/USERij
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
SPH, 2D, Beam, Spring, CFD
Law Name SPH 2D ANALYSIS TRUSS BEAM Spring CFD
Type 36 Type 23 Type 15
/MAT/PLAS_PREDEF
/MAT/LAW0 (VOID)
/MAT/LAW1 (ELAST) √*
/MAT/LAW2 (PLAS_JOHNS) +
/MAT/PLAS_ZERIL
/MAT/LAW3 (HYDPLA) +
/MAT/LAW4 (HYD_JCOOK) +
/MAT/LAW5 (JWL)
/MAT/LAW6 (HYDRO or HYD_VISC) +
/MAT/K-EPS
/MAT/LAW10 (DPRAG1)
/MAT/LAW11 (BOUND)
/MAT/B-K-EPS
/MAT/LAW12 (3D_COMP) +
/MAT/LAW14 (COMPSO)
/MAT/LAW15 (CHANG)
/MAT/LAW16 (GRAY)
/MAT/LAW18 (THERM)
/MAT/LAW19 (FABRI)
/MAT/LAW20 (BIMAT)
/MAT/LAW21 (DPRAG) +
/MAT/LAW22 (DAMA)
/MAT/LAW24 (CONC) ***+
/MAT/LAW25 (COMPSH)
SESAM
USER1
USER2
USER3
/MAT/LAW32 (HILL)
/MAT/LAW34 (BOLTZMAN) √**
/MAT/LAW36 (PLAS_TAB) + **
/MAT/LAW37 (BIPHAS)
/MAT/LAW42 (OGDEN)
/MAT/LAW44 (COWPER)
/MAT/LAW48 (ZHAO)
/MAT/LAW49 (STEINB) +
/MAT/LAW52 (GURSON)
/MAT/LAW54 (PREDIT)
/MAT/LAW58 (FABR_A)
/MAT/LAW63 (HANSEL)
/MAT/LAW66
/MAT/LAW68 (COSSER)
/MAT/LAW69
/MAT/LAW71 √**
/MAT/LAW73
/MAT/LAW74
/MAT/LAW75 (POROUS)
/MAT/LAW76 (SAMP)
/MAT/LAW77
/MAT/LAW78
/MAT/LAW80
/MAT/LAW81 +
/MAT/LAW82
/MAT/LAW83
/MAT/LAW84
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW94 (YEOH)
/MAT/LAW97 (JWLB)
/MAT/LAW100 (MNF)
/MAT/LAW109
/MAT/LAW111
/MAT/LAW116
/MAT/LAW117
/MAT/LAW120 (TAPO)
/MAT/LAW124 (CDPM2)
/MAT/LAW200 (MDS)
/MAT/USERij ****
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
Yes
blank
No
Only for TYPE3
Only for TYPE18 (integrated beam)
LAW24 is compatible with SPH, but not for feature with reinforcement
Isotropic laws only
Compatible with Sol2SPH formulation
