Obsolete
Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
(*) A keyword can become obsolete for several reasons:
- Overtaken by a new and more powerful keyword (ex: FAIL/TAB1)
- No longer used (ex: SHFRA/V4)
- Dismissed (ex: MAT/LAW13)
Note: Obsolete keywords will continue to be supported, but they may no
longer be exposed in upcoming versions of the manual. Also, new keyword are
recommended, instead of obsolete keyword (except,
/LEVSET).
Below is a list of Obsolete Starter keywords:
Obsolete Keywords/Features | As of Version | Replaced with New Keyword |
/FAIL/TAB | v13.0 | /FAIL/TAB1 |
/FAIL/XFEM_FLD | v13.0 | /FAIL/FLD with Ixfem = 1 |
/FAIL/XFEM_JOHNSON | v13.0 | /FAIL/JOHNSON with Ixfem = 1 |
/FAIL/XFEM_TBUTCHER | v13.0 | /FAIL/TBUTCHER with Ixfem = 1 |
/INTTHICK/V5 | v13.0 | |
/LEVSET | v13.0 | /INICRACK |
/MAT/LAW13 (RIGID) | v13.0 | |
/MONVOL/AIRBAG | v13.0 | /MONVOL/AIRBAG1 |
/MONVOL/COMMU | v13.0 | /MONVOL/COMMU1 |
/MONVOL/FVMBAG | v13.0 | /MONVOL/FVMBAG1 |
/PROP/TYPE5 (RIVET) | v13.0 | |
/RIVET | v13.0 | |
/SHFRA/V4 | v13.0 | |
/ALE/DISP | v14.0.220 | /ALE/GRID/DISP |
/ALE/DONEA | v14.0.220 | /ALE/GRID/DONEA |
/ALE/SPRING | v14.0.220 | /ALE/GRID/SPRING |
/ALE/STANDARD | v14.0.220 | /ALE/GRID/STANDARD |
/ALE/ZERO | v14.0.220 | |
/PERTURB | v2017.2 | /PERTURB/PART/SHELL |
Modif Input File | v2018 | |
/INTER/TYPE20 | v2018 | /INTER/TYPE24 |
/MAT/LAW51Iform=3 | v2018 | /MAT/LAW51 Iform = 6 |
/UPWIND | v2018 | /ALE/MUSCL |
/PROP/TYPE14 Isolid=12 | v2018 | /PROP/TYPE14 (SOLID) Isolid=17 |
/CAA | v2020 | /ALE/SOLVER/FINT - Iform=2 |
/ARCH | v2021 | |
/TH/MODE | v2021.1 | |
/SURF/MDELLIPS | v2021.2 | |
/MADYMO/LINK | v2021.2 | |
/SPMD | v2022 | |
/MAT/LAW51Iform=0, 1, 10, 11 | v2023 | |
/INTER/TYPE22 | v2024 |
