Starter Subroutine Initialization RINInn for Spring Elements
This subroutine initializes the user’s spring element.
Arguments
The argument list for RINI
is:
C--------------------------------------------------------------------------
SUBROUTINE RINI30(NEL ,IOUT ,IPROP ,
3 IX ,XL ,MASS ,XINER ,STIFM ,
4 STIFR ,VISCM ,VISCR ,UVAR ,NUVAR )
Definition
| Argument | Format | Description |
| NEL | Integer read only scalar | Number of elements per group. In Radioss Engine subroutines, the element data are treated by groups for vectorization. This argument is machine-dependent and set by Radioss. |
| IOUT | Integer read only scalar | Output file unit (ROOTL00). |
| IPROP | Integer read only scalar | Property number. |
| IX | Integer array read only | Array of size 4*NEL containing spring connectivity.
| XL | Float array read only | Array of size NEL containing current element length. |
| MASS | Float array write only | Array of size NEL containing element mass. |
| XINER | Float array write only | Array of size NEL containing element spherical inertia. |
| STIFM | Float array write only | Array of size NEL containing element translational stiffness in time step computation. |
| STIFR | Float array write only | Array of size NEL containing element rotational stiffness in time step computation. |
| VISCM | Float array write only | Array of size NEL containing element translational viscosity in time step computation. |
| VISCR | Float array write only | Array of size NEL containing element rotational viscosity in time step computation. |
| NUVAR | Integer read only scalar | Number of user element variables. |
| UVAR | Float array read write | Array of size NEL*NUVAR containing user element variables. |
