Connector for Altair IoT Studio
The Altair IoT Studio connector allows reading data from Altair IoT Studio, mostly from AnythingDB OpenAPI endpoints. This dedicated connector is recommended over the standard JSON connector since it can automatically iterate over all the available data from service using next_cursor information in the response. The UI also allows minimal settings required to connect to the Altair IoT Studio OpenAPI endpoints.
NOTE: The Token URL is not visible in the connector. You can set the server-wide token URL in the “connector.oauth.tokenurl” property in the Panopticon.properties file.
- Enter the Client ID, Client Secret, Grant Type, and Scope to connect to Altair IoT Studio.
The Panopticon server builds up the request body formatted as application/x-www-form-urlencoded from these four fields.
- Enter the full URL including any filter query, limit, etc.
For example:
https://api.swx.altairone.com/spaces/altair/categories/ElectronicBoards/things-status?limit=50&property%3Atemp=gt%3A20&property%3Adim=80
- Enter custom Request Headers which enable connection to the API of AnythingDB.
- Enter the Record Path. Default is data.
NOTE: Empty Record Path is allowed.
- Select either the period (.) or comma (,) as the Decimal Separator.
- Click
to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled. - You can also opt to load or save a copy of the column definition.
- Click
to add columns and specify their properties:
Property Description Name
JsonPath
The JsonPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
To delete a column, check its
or all the column entries, check the topmost
, then click .
Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
Set the row limit of the data set. Consequently, the maximum number of records fetched from service is controlled as this setting is used while auto iterating data from service using the next_cursor information in the response.
