Connector for Elasticsearch 7.x
The Elasticsearch 7.x connector allows you to connect and access data from an Elasticsearch cluster using Java High Level REST Client.
NOTE:
- To enable the Elasticsearch 7.x connector, refer to Elasticsearch Connectors Dependency Installation for more information on how to copy the provided dependency files to the Lib folder.
- The Elasticsearch 7.x connector supports Elasticsearch 7.x versions.
- Elasticsearch 6.x and Elasticsearch 7.x connectors will not work in a single Panopticon Real Time instance due to conflicting Elasticsearch API dependencies.
- Enter the following information:
Property Description Host
The hostname of any node in your Elasticsearch cluster, or localhost for a node on your local machine.
Port
The port running the Elasticsearch HTTP service (default is 9300). If the port you wish to use is different from the default port, change the value to the correct one.
User Id
The username used to connect to the Elasticsearch 7.x service.
Password
The password used to connect to the Elasticsearch 7.x service.
Select the Show Characters checkbox to display the entered password characters.
Cluster Name
The cluster name that can be used to discover and auto-join nodes.
Index Name
The Index name in Elasticsearch. This is some type of data organization mechanism that allows partition of data in a certain way.
- Enter an optional JSON-encoded request body in the Query box.
- Click . The columns populate the Output Column section.
- Click to add columns and specify their properties:
Property Description Name
Date Format
Enabled
Determines whether the message field should be processed.
To delete a column, check its
or all the column entries, check the topmost
, then click .
