Connector for Splunk
The Splunk connector allows the retrieval of data from a Splunk instance.
- Enter the following properties:
Property Description Host
Splunk host address.
Port
Splunk host port. Default is 8089.
User Id
The user Id that will be used to connect to the Splunk service.
Password
The password that will be used to connect to the Splunk service.
- Select the Search Type:
- Manual
Proceed to step 5 to define a new search query.
- Saved Search
Allows you to select in the Saved Search drop-down list.
- Manual
- Click
to populate the Application drop-down list and select one. - Select whether the parameters should be automatically enclosed in quotes by selecting the Enclose parameters in quotes checkbox.
- Enter a Search Query.
