Connector for StreamBase 7.1
The StreamBase 7.1 connector allows connection to the StreamBase CEP engine instance on a real-time streaming basis.
To use the StreamBase connector, Streambase 7.1 redistributable must be installed.
Refer to http://www.streambase.com/products/streambasecep/download-streambase/ for more information in downloading StreamBase products.
- Enter the connection details:
Property Description Primary URL
Primary URL of the StreamBase 7.1. Default is sb://localhost:10000.
Secondary URL
Secondary URL of the StreamBase 7.1.
NOTE: More than two StreamBase server URLs can be specified by comma separation.
User Id
User Id that will be used to connect to StreamBase 7.1.
Password
Password that will be used to connect to StreamBase 7.1.
- Click
to return a list of updated streams. Selection of a stream returns a list of available
Id columns for the stream.This populates the Id Column with the set of columns from the schema of type sym and the text array such as Character/Boolean/GUID, etc. The selected Id Column can be used to select a key column to manage data updates and inserts.
- Enter the Predicate expression to force emission.
Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
For this section:
Refer to Define Real-Time Settings for more information.
