Creating a Workbook
A user with a Designer role can create new workbooks and publish them into folders to which the user has permission.
- Create a workbook by doing one of the following:
- Click
on the Welcome or Workbooks page. - Right-click on a folder or sub-folder then select New Workbook in the context menu on the Workbooks page.
The New Workbook dialog displays.
- Click
- Enter the name of the workbook then click
The new workbook with a dashboard page (named Dashboard1) is displayed on the Open Workbook in Design Mode.
The dashboard name by default is editable. You can enter a descriptive dashboard name.
To proceed in creating a workbook, data tables must be added first. On the Data Table pane, there are three options to add or edit data tables.
You can also drag and drop a data file to the dashboard. This opens the Data Table Wizard where you can configure the data table.
See Adding and Managing Data Tables for more information.
