Defining the Style of General Parts
To set the style of a general part, click Style
.The page updates to display the Style pane.
- To modify the Foreground or Background color of the part and title, you can do one of the following:
- Click the Color box to display the Color dialog and set the Hex color code, RGB, or HSL value
- Enter the Hex color code
- Enter the HTML color name
Set the Font type, size, style (Bold and/or Italic).
- Set the Padding of the part.
- To modify the Top, Right, Left, and Bottom padding values, click
The page updates to display the following fields:
- Set the desired padding values. If the values are not the same, Mixed is displayed in the Padding field.
Specify the Border Radius. When set to 0px, the border is displayed as a sharp corner. Setting to higher values makes the border more rounded.
- Set the Margin of the part.
- To define the Top, Right, Left, and Bottom margin values, click
- Set the desired margin values. If the values are not the same, Mixed is displayed in the Margin field.
