Do Not Aggregate
Returns the value of a single row, otherwise null.
This method can be used to display a source table.
Below is a source table showing two fields Number and Arbitrary, with Aggregation set to DoNotAggregate and grouped by the Row field. This means Row is also the Breakdown field.
| Row | Number | Arbitrary |
| A | 1 | 3 |
| B | 2 | 2 |
| C | 3 | 1 |
| D | 4 | 0 |
| E | 5 | -1 |
| F | 6 | -2 |
| G | 7 | -3 |
| H | 8 | 0 |
| I | 9 | 0 |
| J | 10 | 0 |
If there are multiple items or rows without any grouping, then the value of the method is just n/a.
