Modifying User-Defined Columns
A generated column can be modified.
- Modifying user-defined columns can be done either by clicking:
- The Edit
button of a generated column title in the Data Preview - The Calculated Columns button on the Data Sources Settings pane and clicking the generated column to be modified.
The corresponding user-defined settings is displayed.
- The Edit
- Modify the properties or settings and click
to save the changes.
