Defining the Color Palettes of a Theme
When you define the settings of the color palettes, you can manage, import, or export Text, Sequential, and Diverging color palettes.
- To select the Diverging, Sequential, and Text color palettes to use within the workbooks, click the Color Palettes tab.
NOTE: For more information on how to create, modify, duplicate, or delete Single, Sign, Text, Sequential, or Diverging Palettes, refer to the Color Palettes sections.
- Select the checkboxes of the provided color palettes that will be included for each category.
- Click the radio button of the preferred Default color palette for each category.
- To upload color palettes, click
. The Upload Color Palette dialog displays.
- To export color palettes, you can either:
- Click
for all color palettes. The ColorPalettes.excp file is exported.
- Click the Export Palette
icon of a color palette. The <ColorPaletteName>.excp file is exported.
You can move the exported file to the desired location.
- Click
- To replace the color palettes, select the Replace Color Palettes checkbox.
- Click
A notification displays once the color palettes file is uploaded.
Click
to close the dialog. The uploaded color palette is added in the list.
- Proceed to the General Colors tab to specify the general colors of the theme.
