Using OAuth 2.0 Through OpenAM
To enable roles mapping and username retrieval with OpenAM, perform the following configuration in the IdP:
- Add value isMemberOf to the LDAP User Attributes list in your Data Store.
- Add values uid|Username and isMemberOf|Groups to the scopes mapping in your OAuth agent configuration.
Example configuration in Panopticon.properties:
authentication.oauth2.client.id=panopticon
authentication.oauth2.client.secret=password123
authentication.oauth2.identity.attribute.roles=isMemberOf
authentication.oauth2.identity.attribute.roles.pattern=cn=([^,]+)
authentication.oauth2.identity.attribute.username=uid
authentication.oauth2.identity.url=http://localhost:9080/openam/oauth2/tokeninfo
authentication.oauth2.login.callback.url=http://localhost:8080/panopticon/server/rest/auth/login
authentication.oauth2.login.redirect.url=
authentication.oauth2.login.response.type=code
authentication.oauth2.login.scope=uid isMemberOf
authentication.oauth2.login.url=http://localhost:9080/openam/oauth2/authorize
authentication.oauth2.logout.redirect.url=http://localhost:8080/panopticon
authentication.oauth2.logout.url=http://localhost:9080/openam/oauth2/token/revoke
authentication.oauth2.token.method=QUERY
authentication.oauth2.token.url=http://localhost:9080/openam/oauth2/access_token
authentication.type=OAUTH2
