+Creating Amazon Kinesis – Data Streams Data Source
The Amazon Kinesis – Data Streams connector reads records from the given data stream and Shard ID.
- n the New Data Source page, select Input > Amazon Kinesis – Data Streams in the Connector drop-down list.
- You can either:
- Select the Use Default Credentials Chain checkbox to use the default Access Key ID and Secret Key Access, or
- Unselect the Use Default Credentials Chain checkbox and enter the Access Key ID and Secret Key Access
NOTE: The Access Key ID and Secret Key Access from the AWS account can be configured in three places:
- Two properties at the Streams.properties file which is available in the AppData folder of Panopticon Streams
- connector.kinesis.datastreams.accesskeyid
- connector.kinesis.datastreams.secretaccesskey
If this is the used configuration, the Use Default Credentials Chain box is not displayed in the connector UI.
mmm
This is the recommended way to provide the credentials.
- AWS credentials provider chain
- Environment Variables - AWS_ACCESS_KEY_ID and AWS_SECRET_ACCESS_KEY
- Credential profiles file at the default location - ~/.aws/credentials on Linux, macOS, or Unix, and C:\Users\USERNAME\.aws\credentials on Windows.
- Dedicated fields in the connector
Not the recommended configuration.
- Enter the following information:
Property Description Region
Physical location of the data center. The list is picked up from the Amazon Kinesis Data Streams Endpoints and Quotas page.
Stream
Name of the stream from where you want to pull the data. Click Fetch Streams
to load all of the available streams from the AWS account.Shard Id
Each connector instance or data source is connected to only one shard. Click Fetch Shards
to pull all of the shards from the selected stream.From Beginning
The starting position in the data stream from which to start streaming. Default value is unchecked, which means LATEST. When checked, the starting position is set to TRIM_HORIZON.
NOTE: All of the connection settings can be parameterized.
- Select the Message Type.
- Select either the period (.) or comma (,) as the Decimal Separator.
NOTE: Prepend 'default:' for the elements falling under default namespace.
- Click
to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled. - You can also opt to load or save a copy of the column definition.
- You can also opt to click
to add columns to the Amazon Kinesis – Data Streams connection that represent sections of the message. Then enter or select:
Property Description Name
Fix Tag/JsonPath/Text Column Index/XPath
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema.
The data type of the column. Can be a Text, Numeric, or Time.
Date Format
Enabled
Determines whether the message field should be processed.
NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To delete a column, check its
or all the column entries, check the topmost
, then click
. - Define the Real-time Settings.
- Click
. The new data source is added in the Data Sources list.
