Make Board Paneling GUI
- Mirror: Create the duplicated original PCB data by mirroring.
- X Mirror: Mirroring the board based on the X axis.
- Y Mirror: Mirroring the board based on the Y axis.
- Rotation: Create the duplicated original PCB data by rotation.
- Rotation Angle: Enter the angle to be rotated. The rotate direction
is counterclockwise.
- Paneling Object Definition: Define the object to be duplicated.
- Component: Include components placed in PCB data.
- Except Component: Exclude duplicate components. Exclude components
can be specified in the String Filter Set Up
dialog.
Figure 3. - Route: Include Route in PCB data.
- Board Figure: Include Board Figure in PCB data.
- Board Outline: Include Board Outline in PCB data.
- Keep original board’s data: Keep the original board outline of PCB data without deletion when the Board Outline option is not selected.
- Paneling Object Area: Specify the PCB data area to be duplicated.
- Select Rect: Select the rectangular area as the duplicated area.
- Select Area: Select a polygon area as the duplicated area.
- Placement: Define where the duplicated objects are placed.
- Move To: Define the X and Y coordinates where the duplicated PCB
data is placed. The origin coordinate of the original PCB data is
used as the reference point.
Figure 4.
- Object Select: Automatically calculate the movement coordinates by selecting
the pad of the PCB data and the pad of the Bare Board Gerber (Metal Mask)
data in an array.
- Cad Object: Select the reference pad on the PCB design data.
- Gerber Object: Select a pad object that matches the pad selected in CAD data.
Figure 5. - Array: This function is used when the duplicated data is to arrange with the
same distance and angle.
- dX, dY: Set the X and Y axis spacing of the copied sub board.
Figure 6. - Select Object: Automatically calculate dX and dY spacing by selecting two parts from PCB design data.
- Number of Sub Board: Set the number of sub boards to be duplicated in horizontal and vertical directions.
- Add Board: Add the board that is set in Mirror, Rotation, Paneling Object Definition, Paneling Object Area and Placement above to the table.
- Edit: Edit the settings saved board in the table list. Select a board to edit from the list and modify the setting in Mirror, Rotation, Paneling Object Definition, Paneling Object Area and Placement.
- Delete: Delete the selected board from the list.
- Table
- Mirror: Display the mirror status.
- Rotation: Display the rotation angle.
- Placement: Display the placed coordinates of the duplicated board.
- After Complete Paneling, Remove Gerber Data: Delete the Gerber layer after completing the array paneling in the case of using Gerber data.
- Apply: Apply to the PCB design data with the saved settings in the table.
- Initialize: Initialize the settings.
- Define Panel Outline: Create panel outline by designating an area of the
bare board’s location.
- Start Location: Specify the starting coordinates of Panel Outline.
- End Location: Specify the ending coordinates of Panel Outline.
Figure 7. - Line Width: Specify the width of Panel Outline.
- Get Panel Outline from Gerber: Designate the line selected in Gerber
data as the Panel Outline.
Figure 8.
