User Shell Setup
To set up your user shell with Accelerator you need to know where the Altair Accelerator software has been installed.
Ask your system administrator.
User Setup: C-Shell, TCSH
Choose one of two choices:
  1. Modify your ~/.cshrc file directly by adding the following line:
    # Add this to your .cshrc
    source /<installation_directory>/<version>/<platform>/etc/vovrc.csh
  2. Run the vovsetupuser script, which creates a ~/.vovrc file and modifies your ~/.cshrc file to source the ~/.vovrc file.
    % cd <installation_directory>/<version>/<platform>/
    % cd scripts
    % ./vovsetupuser -csh
User Setup: Bourne Shell, K-Shell, Z-Shell, Bash
  1. Source the file $VOVDIR/etc/vovrc.sh. It is recommended that you add the following line to your ~/.profile file:
    # Add this to your .profile or .bashrc
    . <installation_directory>/<version>/<platform>/etc/vovrc.sh
  2. Run the vovsetupuser script.
    % cd scripts
    % ./vovsetupuser -sh
User Setup: Windows Command Shell
If Accelerator is installed in directory R:\opt\altair\vov\2023.1.1, you can set up your cmd shell by executing:
c:> R:\altair\vov\2023.1.1\win64\bat\vovinit.bat
Verify Your Setup
  1. Run the following Altair Accelerator command to verify that your setup works:
    % vovarch
    linux64
  2. Run the command vovversion to show the version of Accelerator that is installed.
    % vovversion
    2023.1.1
