Document Organization
This manual describes the web user interface and provides instructions on common uses and best practices for users. It also provides the basic setup, installation and management practices for administrators. For both administrators and users, it functions as a getting started guide.
- Introduction: This section provides the product information, the document organization, the theory of operations, a system diagram and a description of components.
- Installation: This section describes the system requirements and the installation steps for four different types of installations: Windows Single & Bundled and Linux Single & Bundled.
- First Steps: After you’ve installed Monitor, this section covers what to do next. This applies both to administrators and users, who may be playing dual roles at this point.
- Common Questions and Basic Uses: This section addresses common questions and points you to applicable instructions, as needed.
- Using the Graphical User Interface: This section describes the seven tabs on the Monitor user interface and their usage.
- Basic Operations and Setup (Admin Only): This section reviews general tasks for admins.
- Troubleshooting: The section outlines common problems and provides known solutions.
