Detailed Widget Listing
The following section describes the available widgets and provides example URLs and descriptions of the options for each widget:
Current Checkouts
- Widget Name
- checkouts
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=checkouts
Widget URL options:
Parameter | Default | Possible Values | Meaning |
reportby | taggedfeature | tag, feature, taggedfeature, user, host, account | Report by what. |
tag | any tag name | Show report on this tag only. | |
feature | any feature name | Show report on this feature only. | |
user | any user name | Show report on this user only. | |
host | any host name | Show report on this host only. | |
account | any account name | Show report on this account only. | |
version | any version number | Show report on this version only. | |
filter_tag | any tag name pattern | Filter on tag name. Only show the checkouts with tags matching the pattern. | |
filter_feature | any feature name pattern | Filter on feature name. Only show the checkouts with name matching the pattern. | |
filter_user | any user name pattern | Filter on user name. Only show the checkouts with tags matching the pattern. | |
filter_host | any host name pattern | Filter on host name. Only show the checkouts with tags matching the pattern. | |
filter_account | any account name pattern | Filter on account name. Only show the checkouts with tags matching the pattern. | |
filter_version | any version pattern | Filter on version. Only show the checkouts with versions matching the pattern. | |
limit | 30 | any positive integer | How many checkouts to show on the page. |
ascend | 0 | 0 or 1 | Sort in ascending (ascend=1) or descending (ascend=0) order. |
sortby | handles | tag, feature, taggedfeature, user, host, account, count | Sort on which column. |
nocase | 0 | 0 or 1 | Ignore case for user and host. |
Checkout Statistics
- Widget Name:
- checkoutstats
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=checkoutstats&timerange=Yesterday
Widget URL options:
filter_tag | custom tag name string or regex | Report on only those tags that match above string or regex. | |
filter_feature | custom feature name string or regex | Report on only those features that match above string or regex. | |
filter_user | custom user name string or regex | Report on only those users that match above string or regex. | |
filter_host | custom host name string or regex | Report on only those hosts that match above string or regex. | |
filter_account | custom account name string or regex | Report on only those accounts (projects) that match above string or regex. | |
filter_version | custom version name string or regex | Report on only those verions that match above string or regex. | |
limit | 100 | integer number | Max number of records to show. |
sortby | handles | tag, feature, taggedfeature, user, host, account, count, dur_tot, dur_avg, dur_max, wait_count, wait_tot, wait_avg, wait_max | Sort on which column. |
timerange | Yesterday, Last Week, This Week, Last Month, This Month, Last Quarter, Last Year | Time period on which to to report. Ignored when start/end options are present. | |
start | unix timestamp | Start time (in unix timestamp format) of the reporting period. | |
end | unix timestamp | End time (in unix timestamp format) of the reporting period. |
Checkout Details
- Widget Name:
- checkoutdets
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=checkoutdets
Widget URL options:
sortby | checkouttime | duration, checkouttime, checkintime, queuedtime, tag, feature, user, host, version, handle, origin, tokens, project, reservations, location | Sort checkouts by what. |
account | any account (project) name | Show report on this account only. | |
version | any version name | Show report on this version only. | |
limit | 100 | integer number | Max number of rows to show. |
Checkout Duration Histogram
- Widget Name:
- checkouthistogram
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=checkouthistogram
Widget URL options:
end | unix timestamp | End time (in unix timestamp format) of the reporting period. | |
tag | any tag name | Tag name of the feature on which to report. | |
feature | any feature name | Name of the feature on which to report. | |
user | any user name | Name of the user on which to report. | |
host | any host name | Name of the host on which to report. | |
account | any account name | Name of the account(project) on which to report. | |
version | any version number | Version on which to report. | |
origin | samples, logs, merged | Origin of checkout data. |
Current Feature Information
- Widget Name:
- features
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=features&sortby=inuse&ascend=0&filter_tag=CDN
Widget URL options:
sortby | inuse | tag, vendor, feature expire total users inuse percent oldest | Sort on which column. |
limit | 30 | any positive integer | How many features to show on the page. |
showfeature | active | active|all|perpetual|expiring|expired | Which features to show on the page based on various states. |
vendor | any vendor name | Name of the vendor on which to report. | |
filter_tag | any tag name pattern | Filter on tag name. Only show the features with tags matching the pattern. | |
filter_vendor | any license daemon vendor name | Filter on vendor name. Only show the features with vendor name matching the pattern. | |
filter_feature | any feature name pattern | Filter on feature name. Only show the features with name matching the pattern. |
Feature Statistics
- Widget Name:
- featurestats
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=featurestats
Widget URL options:
sortby | inuse | inuse, tag, feature | Sort on which column. |
limit | 100 | any positive integer | How many features to show on the page. |
filter_feature | any feature name pattern | Filter on feature name. Only show the features with name matching the pattern. | |
showpeakavg | 0 or 1 | Show peak average feature usage. | |
Feature Efficiency Statistics
- Widget Name:
- featureeffstats
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=featureeffstats
Widget URL options:
Feature Efficiency
- Widget Name:
- featureeffhistogram
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=featureeffhistogram
Widget URL options:
timerange | Yesterday, Last Week, This Week, Last Month, This Month, Last Quarter, Last Year | Time period on which to report. Ignored when start= and end= are given. Case-insensitive, e.g. 'last week' means the same as 'Last Week' Older versions used the key showactive for this parameter. Since some possible values contain spaces, you need to URL-encode them, for example timerange=Last+Month | |
showres | 0 | 0, 1 | Show reservations (0=false, 1=true) |
workweek | 0 | 0 , 1 | Limit data to the work week. |
Feature Statistics Plot
- Widget Name:
- featurestatsplot
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=featurestatsplot
Widget URL options:
plotusage | 1 | 0 or 1 | Show feature usage graphically (0=false, 1=true |
plotqueuedrequests | 1 | 0 or 1 | Show queued requests graphically (0=false, 1=true |
plotdenials | 1 | 0 or 1 | Show denials graphically (0=false, 1=true |
Feature Details Plot
- Widget Name:
- featuredetsplot
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=featuredetsplot&tag=CDN&feature=NC-Verilog&timerange=Yesterday
Widget URL options:
width | 600 | integer number | The width of the graph. |
height | 200 | integer number | The height of the graph. |
Denial Statistics
- Widget Name:
- denialstats
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=denialstats
Widget URL options:
reason | |||
Denial Details
- Widget Name:
- denialdets
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=denialdets
Widget URL options:
reason | unknown | unknown, "Licensed number of users already reached", "Feature has expired", "Users are queued for this feature" | Denial reason given by debugLog. |
limit | integer 1 or greater | Display only the indicated number of records. | |
querylimit | integer 1 or greater | Return only up to the number given, from the database. | |
sortby | handle | handle, user, tag, feature, host, reason | Sort report rows by the indicated column. |
ascend | 0 | 0 or 1 | Sort in ascending order (ascend=1) or in descending order (ascend=0). |
Denial Plot
- Widget Name:
- denialplot
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=denialplot
Widget URL options:
ymax | integer 0 or greater | Maximum Y axis value. | |
Feature Activity Heatmap
- Widget Name:
- heatmap
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=heatmap&type=checkout&tag=CDN&feature=NC-Verilog&timerange=Yesterday
Widget URL options:
tag | any tag name | Tag name to map. | |
feature | any feature name | Name of the feature on to map. | |
type | checkout | checkout, checkin, denials | What kind of activity to report on with this heatmap. |
timerange | Yesterday, Last Week, This Week, Last Month, This Month, Last Quarter, Last Year | Time period on which to report. Ignored when start/end options are present. | |
Usage and Denial Pie Chart
- Widget Name:
- piechart
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=piechart&type=duration&tag=CDN&feature=NC-Verilog&timerange=Yesterday
Widget URL options:
tag | any tag name | Tag name of the feature to plot. | |
feature | any feature name | Name of the feature to plott. | |
type | count | count, duration, denials | Get piechart on what for each user. |
start | unix timestamp | Start time (in unix timestamp format) of the plot period. | |
end | unix timestamp | End time (in unix timestamp format) of the plot period. |
Current Server Information
- Widget Name:
- tags
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=tags&sortby=handles&ascend=0&filter_tag=MGC
Widget URL options:
sortby | handles | tag, type, vendor, licserver, status, features, handles or update | Sort on which column. |
limit | 30 | any positive integer | How many daemons to show on the page. |
filter_tag | any tag name pattern | Filter on tag name. Only show the daemons with tags matching the pattern. | |
filter_type | flexlm, lum, etc | Filter on License Manager type, for example specify "flexlm" to show only FlexNet Publisher type license daemons. | |
filter_vendor | any license daemon vendor name | Filter on vendor name. Only show the daemons with vendor name matching the pattern. | |
filter_status | status of the daemon | Filter on license server status. Only show the daemons with license server status matching the pattern. |
Tag Statistics
- Widget Name:
- tagstats
- Example URL
- http://host:port/cgi/ftlm.cgi?widget=tagstats
Widget URL options:
tag | Any valid tag name. | Display tag statistics for the period selected. | |
