Redmark
Redmark is a function to make comments in the design. This function can be used to leave messages or comments to assign tasks.
Create Redmark Comments
Use Redmark to make and save comments in a SDBB file.
In the Redmark menu, click
Redmark.
- The Redmark dialog contains a list of comments.
- Click Add to add a comment and click Remove to remove a comment.
- Click Close to close the dialog.
- To add a comment, enter the comment’s title name.
- Add comments.
- Add File: Attach files.
- Open: Attach files.
- Add Draw Object: Add drawing geometries to show the location or highlight objects.
Done: After adding a comment, click Done. The comment is added to the
list.
Note: The saved SDBB file also keeps comments in it. While opening the schematic design that has Redmarks, PollEx Logic shows design and Redmarks, also. You can also save Redmark file only into file using save button in Redmark window.
