Manage Net Classes
Classify nets according to their electrical characteristics.
From the menu bar, click .
The Net Classes dialog opens displaying a default net class, string filter.
- Use Import and Export to save and reload the net class file.
- Use Edit to edit current net class items.
- Click Add to open the Net Classes dialog.
- Click String search definition to view a document describing the string search rule.
Click Remove to delete a selected class.
You cannot delete the basic net classes.This net class definition will be used in the Properties-Nets dialog to assign net class to each net. By using net class assigned to each net, DDR nets are automatically grouped when performing net analysis.
