Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
The topics discussed in this example are:
  • WallMan
    • Launch WallMan.
    • Import an urban database from a .dxf and convert to a WinProp format.
    • Modify a building in the urban database.
    • Add a tower to a standard building.
    • Add vegetation to the urban environment.
    • Save the urban database.
  • ProMan
    • Launch ProMan.
    • Specify the antenna sites, orientations and properties.
    • Specify the simulation parameters.
    • Specify the computation method.
    • Save the project.
    • Launch the Solver.
    • View the prediction results.
Note: Follow the example steps in the order they are presented as each step uses its predecessor as a starting point.
Tip: Find the completed model in the Altair installation directory, for example:
Altair\2024.1\help\winprop\examples\GetStarted_models\Project3_Urban_Scenario.
