Summary of Wave Propagation Models for Urban Scenarios
A summary of the urban wave propagation models in tabular format.
| Model |
Urban 3D Dominant Path (DPM) |
Urban 3D Intelligent Ray Tracing (IRT) |
ITU-R P.1411 |
COST 231 Walfisch-Ikegami |
| Type | Semi-deterministic | Deterministic | Empirical | Empirical |
| Valid for |
| Accuracy | High accuracy | High accuracy | Good accuracy |
Good accuracy when transmitters are above medium rooftop level. Reduced accuracy when transmitters are below medium rooftop level. |
| Computation Time | Short | Typically minutes after preprocessing for IRT | Very short | Very short |
Preprocessing of Database |
Not required | Yes | Not required | Not required |
Problem Type & Size |
Radio coverage simulation for very large urban areas | Radio channel incl. multipath and radio coverage simulation for large urban areas | Radio coverage simulation for urban areas < 1 km distance | Radio coverage simulation for urban areas < 5 km distance |
| Considers |
Depending on the sub-model, it considers:
| Limitations | Model does not compute the complete channel impulse response | Requires post-processing with knife-edge diffraction model for hilly terrain | Hilly areas are not considered |
Note:
It is not recommended to use the Dominant Path Model (DPM) for the point mode since it may result in accurate results if the points are located far from the prediction height.
Using point mode does not reduce the runtime.
