Measuring an Angle
Use the angle measuring tool to measure or validate the angle (in degrees) between three points in a model.
On the 3D View contextual tabs set, on
the Mesh tab, in the Tools group, click the
Measure Angle icon.
- Under Point1, use Ctrl+Shift+left click to snap to points (for example, named points, geometry points, geometry face centre, geometry edge centre, mesh vertices and grid).
- Repeat Step 2 for Point 2.
Repeat Step 2 for
Point 3.
The angle in degrees is displayed in the Angle (degrees) field.
Click Close to close the dialog.
Figure 1. The Measure angle dialog.
