Excluding a Configuration from the Model
A configuration can be excluded from the solution without removing it from the model.
Note: Excluding a configuration does not delete the configuration.
- In the configuration list, select the configuration that you want to exclude.
From the right-click context menu, select
Include/Exclude.
Figure 1. The
icon indicates that the configuration is excluded from the
solution.
