Exporting a Mesh
Export the model mesh or simulation mesh.
- [Optional] Select the geometry parts or mesh parts to export. If no part is selected, all included meshes of the specified type are exported.
On the Home
tab, in the File group, click the
Export icon. From the drop-down list select the
Mesh icon.
Figure 1. The Mesh Exporter Tool dialog.
If a geometry or mesh part was selected in Step 1, the Only
export selection check box is selected.
- [Optional] To export only the meshes associated with the selected parts, select the Only export selection check box.
- [Optional] To export only the bounding faces of volume meshes (NASTRAN mesh, STL mesh, I‑DEAS mesh), select the Only export bounding faces of volume meshes check box.
- [Optional] To export dimensions in metre for CADFEKO mesh, Feko HyperMesh, NASTRAN mesh or STL mesh, select the Scale to metre check box.
If the model contains mesh parts (imported meshes) and simulation meshes
(meshed geometry or remeshed mesh parts), the options under Specify which
mesh to export are enabled.
Under Specify which mesh to export, select one of the
following:
- To export the meshed model of the geometry or the remeshed version of an imported mesh, click Simulation mesh.
- To export an imported mesh, click Model mesh.
Click OK to export the mesh and to close the
dialog.
CAUTION: Exporting a .fhm file replaces the .inc file of the same name (if it exists).
