Creating an Impedance Sheet
Define a frequency-dependent impedance sheet. Apply the impedance sheet to wires or faces bordering free space or a dielectric region.
On the Construct tab, in the Define group, click the
Media icon. From the drop-down list, select the
Impedance Sheet icon.
Figure 1. The Create Impedance Sheet dialog.
- In the Definition method field, from the drop-down list select Frequency independent.
- In the Real part field, enter a value for the real part of the impedance sheet.
- In the Imaginary field, enter a value for the imaginary part of the impedance sheet.
Specify the frequency points manually or import them from a
file.
Select one of the following:
- To import the frequency points from a file, click Import
points.
- In the File name field, browse for the file you want to import.
- [Optional] In the Scale by field, enter a value to scale the points.
- Under Delimiter, click the delimiter type you use in your file.
- Click OK to close the Import Points dialog.
points.
- In the Label field, enter a unique label for the impedance sheet.
- Click Create to create the impedance sheet and to close the dialog.
