Model Protection Limitations
There are various restrictions on simulations that include password-protected models. Some restrictions are imposed to protect the information contained inside the protected model, while other restrictions will be lifted in future releases,
The process of running a simulation with a model that includes imported protected models is the same as for a model that does not contain imported protected models. Various limitations on output file formats and solution output will be imposed when parts of the simulation are protected. Some parts of text files (such as the .pre file) will be encrypted and will not be editable or readable. The solver will limit details written to the screen as well as output files and certain output files, such as export of files for thermal analysis, are not supported and if requested, the setting to write out these files will be ignored. Some requests, most notably currents, will be excluded from the simulation even if the requests are defined. Near fields can be requested and will be calculated, but only the results that fall outside the bounding box of the protected part will be available. Warning and error messages in the CADFEKO notification centre will indicate where these limitations are applied.
| Protected Model | Rest of Model | Info |
| SEP | Windscreen | Protected model contains dielectric(s) using SEP. Rest of model contains mesh elements solved with the Windscreen method. |
| SEP | SEP with MLFMM | Protected model and rest of model contain dielectric(s) using SEP. The MLFMM solver is activated. |
| SEP | FEM | Protected model contains dielectric(s) using SEP. Rest of model contains dielectric(s) using FEM. |
| MoM | UTD | Protected model contains metallic-only faces using MoM. Rest of model contains faces set to UTD. |
| MoM | RL-GO | Protected model contains metallic-only faces using MoM. Rest of model contains faces set to RL-GO. |
| MoM | PO | Protected model contains metallic-only faces using MoM. Rest of model contains metallic-only faces set to PO. |
| PO | MoM | Protected model contains metallic-only faces using PO. Rest of model contains metallic faces set to MoM. |
| PO | MLFMM | Protected model contains metallic-only faces using PO. The MLFMM solver is activated. |
