Cone
Create a cone.
On the Construct tab, in the Create Solid group, click the
Cone icon.
Tip: Press C,5 to use the shortcut key.
Method 1: Base centre, base radius, height, top radius
Base centre (B) | The centre of the base of the cone. |
| Base radius (Rb) | The radius of the cone base (parallel to the UV plane). | |
| Height (H) | The cone height in the N direction measured from B. | |
| Top radius (Rt) | The radius of the cone top (parallel to the UV plane). |
Method 2: Base centre, top centre, base radius, top radius
| Top centre (T) | The centre of the top of the cone. | |
| Base radius (Rb) |
The radius of the cone base (perpendicular to the line from B to T). |
Method 3: Base centre, base radius, height, cone angle
| Base radius (Rb) |
| Height (H) | The cone height in the N direction. | |
| Flare angle (A) | The growth angle measured from the N axis. |
Method 4: Base centre, top centre, base radius, cone angle
| Base radius (Rb) | The radius of the cone base (perpendicular to the line from B to T). | |
| Flare angle (A) |
The growth angle measured from the line defined between B to T. |
