Power
View the quantities and properties that are available for power.
On the Home tab, in the
Add results group, click the
Power icon.
The available quantities for power differ substantially based on the selected entity. For example a load does not have the Active power quantity.
| Quantity | Power | FarField | NearField |
| Active power | |||
| Loss power | |||
| Efficiency | |||
| Total radiated power | |||
| Power transmitted through surface |
Note: The result palette for loads has a similar layout except there is no
Port number.
