FEMT 2023: Modification of scales
Introduction
Since FEMT 2023, it is possible to modify the scales of all efficiency maps:
- graphically
- manually
Steps for graphical modification of scales
- Click on
- On the efficiency map, do a rectangle selection
→ Map rebuilding takes a few seconds
→ Recomputed efficiency maps are updated
Before modification After modification
Steps for manual modification of scales
- Edit the value you want to modify
Modify the wished value and validate with the Enter key
Edit and Modify other values if you want
Validate all modifications by clicking on
Notes
Important: The modification is applied to all
displayed efficiency maps.
Note: After modification, it is possible to reset the scale
values by clicking on
Note: These modifications are only taken into account when
displaying efficiency maps. The new values are not taken into account when
exporting a test.
