2D Curve: display/hide
Introduction
Once the 2D curve has been created, then it can be displayed on a sheet or hided.
Display a 2D curve
To display a 2D curve:
Step | Action |
1 | Select in the Data tree the desired 2D curve |
2 | Activate the contextual menu by click right on the selected 2D curve |
3 | In the contextual menu click on Display |
→ | The corresponding sheet is displayed |
Note: It is possible to display several 2D curves, each sheet with its own tab that can
be activated or not, which permits to hide a 2D curve without concealing it.
Hiding a 2D curve
To hide a 2D curve:
Step | Action |
2 | Activate the contextual menu by clicking right on the selected 2D curve |
3 | In the contextual menu click on Hide |
→ | The corresponding sheet is hided |
Note: It is equally possible to conceal one 2D curve, starting from the corresponding tab
to its sheet by clicking on
