Flux in SimLab : PE / SCAC Examples
List of SimLab examples using :
- Parasitic Extraction solution
- Supplied Conductors AC solution
Note: The used solver is MIPSE
PE Examples
| Solution | Example | Description | Illustration |
| Parasitics Extraction | Power Module | The studied device is a power electronic module component. The entire module is assumed to be made of conducting material and the goal is to compute the Z and S parameter. |
SCAC Examples
| Supplied Conductors AC | Bus Bar | The device studied is a busbar. It is a copper device and the purpose is to calculate the joule losses in the geometry, and the electric current in the RL loads. |
Note: Several tutorials are also available on SimLab Learning Center.
