Evaluating iron losses à priori in magnetic cores
Introduction
- Isotropic hysteretic, Preisach model described by 4 parameters of a typical cycle and
- Isotropic hysteretic, Preisach model identified by N triplets
- Isotropic hysteretic, Jiles-Atherton model
The materials having these types of B(H) property take into account ferromagnetic hysteresis phenomena during the resolution of the project and so, they allow a direct or a priori evaluation of hysteresis and iron losses in the ferromagnetic materials.
- Static and dynamic hysteresis
- Evaluating hysteresis and iron losses in Flux with a hysteretic material
- Application example
- Bibliographical references
During their operations, several parts of electromechanical devices are subjected to time-varying magnetic fields, which generate - in the volumes made of ferromagnetic materials exhibiting a hysteretic behavior - the so-called hysteresis losses: in fact, during the demagnetization processes the material does not give fully back the energy stored during magnetization phases, but it dissipates part of this energy in the form of heat.
Moreover, the magnetic field variations induce - in the conducting volumes - eddy currents (also called Foucault currents) which result in losses via the Joule effect. These two contributions create what is usually referred to as iron losses which are identified by the following general expression:
(1)
where:
- dP: the iron loss density (W/m³) ;
- H: the magnetic intensity (A/m) ;
- B: the magnetic flux density (T) ;
- ρ: the electrical resistivity of the material (Ω.m) ;
- J: the induced current density (A/m²).
In (1), the two aforementioned contributions can be clearly distinguished. In case of slowly varying fields, the Joule losses term is small because the induced currents are negligible and the losses are almost purely hysteretical in nature. On the other hand, when the time rate of change of the fields increases (i.e. the frequency increases), both the hysteresis losses and the Joule losses tend to increase.
To represent graphically this behaviour, another expression - similar to (1) - for the iron loss density dP can be derived by using measurable macroscopic quantities (further details in the bibliographical references at the end of this page):
(2)
where:
- dP is the iron loss density in the region (W/m³) ;
- Hs is the surface magnetic intensity on the region (A/m) and
- Ba is the average magnetic flux density in the cross section of the region (T).
The unique term on the right hand side of this equation (2) accounts for both hysteresis and eddy current losses, because Hs and Ba are functions of the overall distribution of the fields in the region (including the contribution arising from eddy currents at higher frequencies) and so the term accounts for the full iron losses and not only for the hysteresis losses.
- at low frequencies, the hysteresis cycle is narrow due to negligible induced currents and Joule losses: these circumstances are usually referred to as static hysteresis;
- at higher frequencies, the hysteresis cycle Ba(Hs) widens due to the development of induced currents leading to Joule losses: these situations are identified as dynamic hysteresis.
- Represent static hysteresis only: a material containing a hysteretic B(H) property based on the Preisach or the Jiles-Atherton models must be defined and assigned to a magnetic non-conducting region. This approach is well-adapted for low frequency problems.
- Include dynamic hysteresis, i.e. evaluate increased iron losses due to eddy currents: the material containing a Preisach or Jiles-Atherton B(H) property must also have a J(E) property and be assigned to a solid conductor region instead of a magnetic non-conducting region.
- which is available in the formula editor under the button dPowerMag / dV to be used for graphical displaying of the magnetic power density (i.e. the hysteresis loss density) in post-processing (e.g. isovalues);
- and which can be integrated over the region volumes by means of a Sensor to get the whole dissipated
power associated to the static hysteresis (i.e., the hysteresis
losses):
- create a Sensor through the menu Parameter/Quantity or Computation depending if the project is not solved yet or already solved, respectively;
- choose Predefined as type of sensor;
- and Magnetic power as quantity to compute;
- select the magnetic non-conducting regions with a hysteretic B(H) property;
- evaluate the sensor.
- which is available in the formula editor under the button dPower / dV to be used for graphical displaying of the total power density (i.e. the iron loss density) in post-processing (e.g. isovalues);
power associated to the dynamic hysteresis (i.e., the iron losses):
- choose Integral as type of sensor;
- select the solid conductor regions containing the hysteretic B(H) property and a conductivity model J(E);
- in the field Spatial formula, select the quantity dPower / dV in the formula editor;
Material | Active property | Region | Computation method | Evaluated quantity |
Hysteretic Isotropic Material characterized by a Preisach-type model or Isotropic soft magnetic material: hysteresis Jiles-Atherton model |
B(H) | Magnetic non-conducting | Predefined sensor (type magnetic power) on a region (quantity dPowMagV) |
Hysteresis losses |
B(H) and J(E) | Solid Conductor | Sensor evaluating the integral of the quantity dPowV on a region | Iron losses |
Application example
- the static hysteresis approach: based on a material containing a Preisach B(H) property assigned to a magnetic non-conducting region;
- the dynamic hysteresis approach: based upon a material containing both a Preisach B(H) property and a isotropic linear J(E) property assigned to a solid conductor region.
The two voltage sources that feed the circuit impose a sinusoidal voltage with an amplitude of 14.5 V and a phase shift of 90° between these them. Several computations were performed, with the frequency of the voltage sources going from 1 to 100 Hz and with both approaches. The goal is to compare the hysteresis losses with the total iron losses for each frequency.
- H. Pfützner and G. Shilyashki, "Theoretical Basis for Physically Correct Measurement and Interpretation of Magnetic Energy Losses," in IEEE Transactions on Magnetics, vol. 54, no. 4, pp. 1-7, April 2018, Art no. 6300207, doi: 10.1109/TMAG.2017.2782218.
- M. Tousignant. Modélisation de l’hystérésis et des courants de Foucault dans les circuits magnétiques par la méthode des éléments finis. Energie électrique. Université Grenoble Alpes; Polytechnique Montréal (Québec, Canada), 2019. (in French). ⟨NNT : 2019GREAT065⟩. ⟨tel-02905410⟩
