Mouse Controls
Mouse controls are used to pan, zoom, and rotate the model.
Inspire offers two types of camera rotation:
- Turntable rotation restricts the rotation to the x-y plane, which is useful if your model's vertical direction is aligned with the z-axis.
- Trackball rotation allows the model to tumble freely in any direction.
| To do this... | Press | Or |
| Pan |
| Trackball Rotation | ![]() |
Ctrl +![]() |
| Turntable Rotation | Shift +
| Zoom About the Mouse Cursor | ![]() |
| Dynamic Zoom About Screen Center | Ctrl + Shift +
Tip:
- You can customize the mouse button/keystroke combinations used to pan, zoom, and rotate so they match other commonly used CAD applications using the window.
- Inspire supports the 3Dconnexion peripherals. No additional setup is required, but the device needs to be connected to your computer before Inspire is launched.
