Rotate Objects
Rotate objects around an axis.
Rotate Objects Around an Axis
Rotate objects around a reference axis with the ability to use a variable.
Select the Move tool, or press
M or T.
- In the guide panel, select the Rotate tab.
- Next to Part, the Select button is active. Select one or more objects.
Define the Direction:
