CAD Import Process
CAD import occurs in three steps: (1) pre-processing, (2) conversion from a third-party format to Parasolid where applicable, and (3) post-processing of the Parasolid model.
1. Pre-processing
| Format | Description |
| Parasolid | Parasolid is used for pre-processing .x_b, .x_t, .xmt_bin, and .xmt_txt models. |
| JT | JTOpen is used for pre-processing .jt models. |
| CT | XT-based CAD formats (SW, NX): These formats don't require pre-processing by the CoreTechnologie KERNEL_IO. |
Non XT-based CAD formats: CoreTechnologie KERNEL_IO is
used for pre-processing non XT-based CAD formats. The CT model
is prepared as follows:
2. Conversion from a Third-Party Format to Parasolid (Where Applicable)
| JT | JTOpen provides direct conversion to Parasolid parts. |
| CT | XT-based CAD formats (SW, NX): Parts don't need to be converted to Parasolid, as the CT model provides XT blocks containing the Parasolid parts. |
Non XT-based CAD formats: The CT model is converted as
follows:
3. Post-processing of the Parasolid Model
Parasolid parts are checked for valid geometry.
Important: Before importing CAD, turn on the
ability to run diagnostics in the Preferences:
Once you turn on With diagnostics, you have
the following post-processing options:- On the File menu, click the Preferences button to open the Preferences window.
- Under Category, select Inspire > Geometry.
- Under Preference, scroll down to Import from CAD File.
- For Fastest import, select With diagnostics.
| Option | Type | Description |
| Solidify | Post-processing | When there are issues such as gashes, small missing faces,
sliver faces (faces that were deleted because they were
non-tessellated), you can turn on this option to help make parts
solid. When tessellation partially fails, non-tessellated faces are deleted and the Solidify operation is performed again. |
| Reset Edge Precision | Post-processing | Recalculate the tolerant edge geometry to improve
precision. While turning this option may not topologically or visually modify the part, it may fix some failing modeling operations. |
Note: Solidify and Reset Edge Precision are the only
post-processing options relevant to XT-based CAD formats (Parasolid, JT, SW,
NX). Since XT-based CAD parts don't need to be converted to Parasolid, Healing
(aka Pre-healing), Alternate Convert, and Sewing aren't applicable.
