Apply an Environment from the Render Library
You can choose from a variety of preset environments. If you can't find exactly what you want, you can choose something similar and modify it. You can also reuse a custom environment that you have previously saved.
On the ribbon, select the Rendering tool.
The Render Library is displayed. -
Select the Environments tab.
Double-click an environment.
The environment is applied to the scene.
