Command Line Options and Configuration Files
Each program requires zero or more options. These options may be supplied on the command line or placed in one or more configuration files.
acuRun -pb channel -inp channel.inpproblem= channel
input_file= channel.inpacuRunIf both command line argument and configuration options are provided, the former takes precedence.
acuRun -pb channelacuRun -problem channelproblem= channelpb= channelThe descriptive name is meant to be used in the configuration files, while the abbreviated name is meant for the command line argument.
setenv ACUSIM_CNF_FILES ./Acusim.cnf:~/Acusim.cnf:/ACUSIM/Acusim.cnf./Acusim.cnf:~/Acusim.cnfEmpty lines and lines starting with a hash (#) are ignored in configuration files. All unrecognized options are also ignored. Each recognized line consists of one option and its value; they are separated by an "=" and any (or no) amount of white space (tabs and blanks).
acuRun -inp channel.inp -hacuRun:
acuRun: Usage:
acuRun:
acuRun: acuRun [options]
acuRun:
acuRun: Options:
acuRun:
acuRun: -h print usage and exit
acuRun: help= TRUE [command-line]
acuRun: -pb <str> problem name
acuRun: problem= channel [./Acusim.cnf]
acuRun: -inp <str> input file name (_auto, use <problem>.inp)
acuRun: input_file= channel.inp [command-line]
acuRun: -v <int> verbose level
acuRun: verbose= 1 [default]
acuRun:
acuRun: Configuration Files:
acuRun:
acuRun: ./Acusim.cnf:~/Acusim.cnf:/ACUSIM/Acusim.cnf
acuRun:
acuRun: Release: 1.7
acuRun:verbose= 1verbose= 1
acuRun.verbose= 0The verbose value of 1 is used by all programs except AcuRun, which uses the value of 0.
verbose= 1
HP.verbose= 2HP.acuRun.verbose= 0
acuRun.SUN.verbose= 1Each option has one of five types.
String (str)
acuRun -problem channelproblem= channelacuTrans -osis "wall surface"surface_integral_output_sets= wall surfaceEnumerated (enum)
acuTrans -to tabletranslate_to= tablecauses AcuTrans to translate its output data to table format.
Boolean (bool)
acuRun -echoacuRun -no_echoecho_input= yesecho_input= FALSEInteger (int)
acuRun -np 4num_processors= 4Real (real)
acuSurf -angle 89.9max_angle= 89.9
