Curve()
Creates a curve with the styles provided.
Usage
curve = Curve( x, y,
name = None, lineType = "solid",
lineWidth = 1, symbol = None,
symbolSize= 1, color = "blue" )Parameters
- x (array)
- The value of the X data of the curve.
- y (array)
- The value of the Y data of the curve.
- name (string)
- The curve's name.
- lineType (string)
- The curve's line types. Valid values are solid(-), dashed(--), dash-dot(-.) and dotted(:).
- lineWidth (integer)
- The curve's line width.
- symbol (string)
- The curve's symbol. Valid values are points(.), pixels(,), circle(o), triangleUp(^), triangleDown(v), triangleLeft(<), triangleRight(>), square(s), plus(+), cross(x), diamond(D), thinDiamond(d), tripodDown(1), tripodUp(2), tripodLeft(3), tripodRight(4), hexagon(h), rotatedHexagon(H), pentagon(p), verticalLine( | ) and horizontalLine( _ ).
- symbolSize (integer)
- The curve's symbol size.
- color (string)
- The curve's color string. Valid values are blue(b), green(g), red(r), cyan(c), magenta(m), yellow(y), black(k) and white(w).
Return Value
- curve (dictionary)
- The created curve information.
This routine creates a curve with the styles provided. The curve x and y data are given by x and
y. The curve name, line type, line width, symbol, symbol size and color are given by
name, lineType,
lineWidth, symbol,
symbolSize and color, respectively. For
example,
nOsiVars = adb.get( "nOsiVars" )
presId = -1
massId = -1
for i in range( nOsiVars ):
name = adb.get( "osiVarName", i )
if name == "pressure": presId = i
if name == "mass_flux": massId = i
nOsfs = adb.get( "nOsfs" )
inletId = -1
for i in range(nOsfs):
name = adb.get( "osfName", i )
if name == "inflow": inletId = i
pres = adb.get( "osiValues", inletId, presId )
mass = adb.get( "osiValues", inletId, massId )
mpCurve = Curve ( pres, mass, name = "Mass Flux",
color = "Red" )
