udfGetEbcNQuads()
Return the number of quadrature points of the quadrature rule for the surface set.
nQuads = udfGetEbcNQuads( udfHd ) ;
AcuSolve User-Defined Example Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nQuads (integer)
- Number of quadrature points of the quadrature rule for the surface set.
This routine returns the number of quadrature points of the quadrature rule for the surface set.
For
example,
Integer nQuads ;
nQuads = udfGetEbcNQuads( udfHd )Errors
- This routine expects a valid udfHd.
- This routine may only be called within an Element Boundary Condition user function.
