udfPrintMessPrim()
Print a message to the standard output, or .log file, if active, for the primary processor/subdomain.
udfPrintMessPrim( udfHd, format, ... ) ;
AcuSolve User-Defined Function Basic
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- format (string)
- C printf() format.
- ... (vararg)
- List of C variables.
Return Value
None
This routine prints a message to the standard output, or the .log file, if active,
but only for the primary processor or subdomain. The argument list
is the same as that of fprintf(, except that here
udfHd takes the place of the file
descriptor. For
example,
udfPrintMessPrim( udfHd, "return value is %g", outVec[0] ) ;Errors
This routine expects a valid udfHd.
