VISCOSITY_MODEL
Specifies a viscosity model for the flow equation.
AcuSolve Command
VISCOSITY_MODEL("name") {parameters...}
Qualifier
User-given name.
type (enumerated) [=none]
Type of the viscosity.
constant or const
Constant viscosity. Requires viscosity.
ramped or ramp
Ramp the viscosity to a constant value. Requires viscosity.
power_law
Non-Newtonian power law viscosity model. Requires power_law_viscosity, power_law_time_constant, power_law_index and power_law_lower_strain_rate.
bingham
Non-Newtonian Bingham viscosity model. Requires bingham_viscosity, bingham_yield_stress, bingham_stress_growth_exponent, bingham_time_constant, bingham_index and bingham_infinite_shear_viscosity.
carreau
Non-Newtonian Carreau-Yasuda viscosity model. Requires carreau_zero_shear_viscosity, carreau_infinite_shear_viscosity, carreau_time_constant, carreau_index and carreau_transition_index.
gas_kinetic
Gas kinetic viscosity model for gases only. Requires GAS_KINETIC_MODEL.
sutherland
Sutherland temperature dependent viscosity model. Requires sutherland_reference_viscosity, sutherland_reference_temperature, sutherland_constant.
piecewise_linear or linear
Piecewise linear curve fit. Requires curve_fit_values and curve_fit_variable.
cubic_spline or spline
Cubic spline curve fit. Requires curve_fit_values and curve_fit_variable.
user_function or user
User-defined function. Requires user_function, user_values and user_strings.
viscosity or visc (real) >=0 [=0]
Constant value of the dynamic viscosity. Used with constant and ramped types.
power_law_viscosity (real) >=0 [=0]
Power law model reference viscosity. Used with power_law type.
power_law_time_constant (real) >=0 [=0]
Power law model time constant. Used with power_law type.
power_law_index (real) [=1]
Power law model power index. Used with power_law type.
power_law_lower_strain_rate (real) >=0 [=0]
Power law model lower limit of strain rate. Used with power_law type.
bingham_viscosity (real) >0 [=1]
Bingham model reference viscosity. Used with bingham type.
bingham_yield_stress (real) >=0 [=0]
Bingham model yield stress. Used with bingham type.
bingham_stress_growth_exponent (real) >0 [=500]
Bingham model unyielded stress region growth rate exponent. Used with bingham type.
bingham_time_constant (real) >0 [=1]
Bingham model power law time constant. Used with bingham type.
bingham_index (real) [=1]
Bingham model power law index. Used with bingham type.
bingham_infinite_shear_viscosity (real) [=0]
Bingham model minimum viscosity. Used with bingham type.
carreau_zero_shear_viscosity (real) >=0 [=0]
Carreau model viscosity at zero shear rate. Used with carreau type.
carreau_infinite_shear_viscosity (real) >=0 [=0]
Carreau model viscosity at infinite shear rate. Used with carreau type.
carreau_time_constant (real) >=0 [=0]
Carreau model power law time constant. Used with carreau type.
carreau_index (real) [=1]
Carreau model power law index. Used with carreau type.
carreau_transition_index (real) >0 [=2]
Carreau model transition index. Used with carreau type.
carreau_temperature_dependence_type (enumerated) [=none]
Types to add the temperature dependence terms to the Carreau Yasuda viscosity material to account for shear heating due to viscous dissipation. Used with carreau type when temperature = advective_diffusive under the EQUATION command and viscous_heating = on in ELEMENT_SET.
Arrhenius
Arrhenius model. Requires activation energy.
William_Landel_Ferry
William Landel Ferry (WLF) model. Requires William_Landel_Ferry_coefficient_C1, William_Landel_Ferry_coefficient_C2, glass_transition_temperature.
exponential
Exponential model. Requires exponential_reference_temperature and exponential_beta_coefficient.
activation_energy (real) >0 [=16628]
Arrhenius model constant to define the temperature sensitivity. Used with carreau type and carreau_temperature_dependence_type = Arrhenius.
William_Landel_Ferry_coefficient_C1 (real) > 0 [=17.44]
William-Landel-Ferry (WLF) model constant. Used with carreau type and carreau_temperature_dependence_type = William_Landel_Ferry.
William_Landel_Ferry_coefficient_C2 (real) > 0 [=51.6]
glass_transition_temperature (real) > 0 [=320]
Glass transition temperature used in the William-Landel-Ferry (WLF) model. Used with carreau type and carreau_temperature_dependence_type = William_Landel_Ferry.
exponential_reference_temperature (real) > 0 [=350]
Reference temperature defined in the exponential model. Used with carreau type and carreau_temperature_dependence_type = exponential.
exponential_beta_coefficient (real) > 0 [=0.005]
Exponential model constant. Used with carreau type and carreau_temperature_dependence_type = exponential.
sutherland_reference_viscosity (real) > = 0 [=0.01716]
Sutherland model reference viscosity at sutherland_reference_temperature. Used with sutherland type.
sutherland_reference_temperature (real) > 0 [=273]
Sutherland model reference temperature corresponding to sutherland_reference_viscosity. Used with sutherland type.
sutherland_constant (real) > 0 [=111]
Sutherland model constant. Used with sutherland type.
curve_fit_values or curve_values array [={0,0}]
A two-column array of independent-variable/viscosity data values. Used with piecewise_linear and cubic_spline types.
curve_fit_variable or curve_var (enumerated) [=temperature]
Independent variable of the curve fit. Used with piecewise_linear and cubic_spline types.
x_coordinate or xcrd
X-component of coordinates.
y_coordinate or ycrd
Y-component of coordinates.
z_coordinate or zcrd
Z-component of coordinates.
x_reference_coordinate or xrefcrd
X-component of reference coordinates.
y_reference_coordinate or yrefcrd
Y-component of reference coordinates.
z_reference_coordinate or zrefcrd
Z-component of reference coordinates.
pressure or pres
Pressure.
temperature or temp
Temperature.
species_1 or spec1
Species 1.
species_2 or spec2
Species 2.
species_3 or spec3
Species 3.
species_4 or spec4
Species 4.
species_5 or spec5
Species 5.
species_6 or spec6
Species 6.
species_7 or spec7
Species 7.
species_8 or spec8
Species 8.
species_9 or spec9
Species 9.
strain_rate_second_invariant or strain_i2
Second invariant of the strain rate tensor.
user_function or user (string) [no default]
Name of the user-defined function. Used with user_function type.
user_values (array) [={}]
Array of values to be passed to the user-defined function. Used with user_function type.
user_strings (list) [={}]
Array of strings to be passed to the user-defined function. Used with user_function type.
multiplier_function (string) [=none]
User-given name of the multiplier function for scaling the viscosity. If none, no scaling is performed.
This command specifies a dynamic viscosity model for the flow (momentum) equation. This model is only applicable to fluid element sets.
VISCOSITY_MODEL commands are referenced by MATERIAL_MODEL commands, which in turn are referenced by ELEMENT_SET commands:
VISCOSITY_MODEL( "my viscosity model" ) {
   type                                = constant
   viscosity                           = 1.781e-5
 MATERIAL_MODEL( "my material model" ) {
   viscosity_model                     = "my viscosity model"
 ELEMENT_SET( "fluid elements" ) {
   material_model                      = "my material model"
   medium                              = fluid
The viscous stress tensor is given by:
where μ is the dynamic viscosity and ∇ s u is the symmetric part of the strain-rate tensor.
A constant type applies a spatially constant viscosity model, as in the above example. This is the simplest case of a Newtonian model for the stress tensor.
The power_law type defines a non-Newtonian viscosity model in which the dynamic-viscosity is a function of the velocity field:
μ = μ 0 [ η 2 max ( I 2 , S min 2 ) ] ( n − 1 ) / 2
where μ 0 is the reference viscosity, given by power_law_viscosity; η is the time constant, given by power_law_time_constant; n is the power index, given by power_law_index; Smin is the lower limit of the strain rate, given by power_law_lower_strain_rate; and I2 is the second invariant of the strain rate tensor:
I 2 = 2 ∇ s u   :   ∇ s u
One of the commonly used models for characterizing non-Newtonian viscosity fluids is the power law model. This model describes the behavior of shear thinning fluids, where the viscosity decreases as the shear rate increases. The relationship between the viscosity μ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0gaaa@37AD@ and the shear rate γ ˙ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4SdCMbai aaaaa@37A7@ can be expressed as follows:
μ=m   γ ˙ n−1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0JaamyBaiaaykW7caaMc8Uafq4SdCMbaiaadaahaaWcbeqaaiaa d6gacqGHsislcaaIXaaaaaaa@4133@
where μ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0gaaa@37AD@ represents the viscosity (Pa sec),   γ ˙ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGPaVlqbeo 7aNzaacaaaaa@3932@ is the shear rate (1/sec), n is the power law index; m     MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyBaiaayk W7caaMc8oaaa@39FE@ is the flow consistency.
To determine the power law index (n) and the flow consistency (m), curve fitting is performed using the rheometer measurement.
Note: The power-law equation (Eq. 2) used in AcuSolve is different from the typical power model, requiring a conversion process to obtain the input parameters for the AcuSolve's Power Law viscosity model (Eq. 2).
For example, if the viscometer measurement yields the following curve-fit result
μ=200   γ ˙ −1.05 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0JaaGOmaiaaicdacaaIWaGaaGPaVlaaykW7cuaHZoWzgaGaamaa CaaaleqabaGaeyOeI0IaaGymaiaac6cacaaIWaGaaGynaaaaaaa@43A9@
The power index ( n = − 0.05 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBaiabg2 da9iabgkHiTiaaicdacaGGUaGaaGimaiaaiwdaaaa@3BC2@ ) can be obtained from − 1.05 = n − 1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeyOeI0IaaG ymaiaac6cacaaIWaGaaGynaiabg2da9iaad6gacqGHsislcaaIXaaa aa@3D6B@ . The power law viscosity can be calculated by substituting 200 to the equation 2 as shown below. It is important to account for a factor of 2 due to definition of the second invariant of the strain tensor:
200 = μ 0 ​ 2 ( n − 1 ) / 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGOmaiaaic dacaaIWaGaeyypa0JaeqiVd02aaSbaaSqaaiaaicdaaeqaaOGaaGza VlaaikdadaahaaWcbeqaaiaacIcacaWGUbGaeyOeI0IaaGymaiaacM cacaGGVaGaaGOmaaaaaaa@43A9@
Thus, power law viscosity is μ 0 =287.8 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd02aaS baaSqaaiaaicdaaeqaaOGaeyypa0JaaGOmaiaaiIdacaaI3aGaaiOl aiaaiIdaaaa@3D56@ .
The power law time constant η MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4TdGgaaa@37A3@ is typically set to 1, and the maximum shear rate should be 0.1 or less to ensure that it corresponds to the maximum viscosity.
VISCOSITY_MODEL( "Basic Power Law" ) {
  type = power_law
  power_law_viscosity = 287.8
  power_law_time_constant = 1.0
  power_law_index = -0.05
  power_law_lower_strain_rate = 0.1
The bingham type defines another non-Newtonian viscosity model in which Papanastasiou's unyielded stress region and power law modifications are added to the basic Bingham viscosity model:
μ = μ ∞ + ( μ 0 − μ ∞ ) ( η g ) n − 1 + τ y g ( 1 − e − M g )
where μ 0 is the reference viscosity, given by bingham_viscosity; η is the time constant, given by bingham_time_constant; n is the power index, given by bingham_index; τ y is the yield stress, given by bingham_yield_stress; M is the unyielded stress region growth rate exponent, given by bingham_stress_growth_exponent; μ ∞ is the viscosity at infinite shear rate (or equivalently the minimum viscosity), given by bingham_infinite_shear_viscosity; and g is the square root of the second invariant of the strain rate tensor:
g = 2 ∇ s u   :   ∇ s u
This may be used as a basic Bingham viscosity model, μ = μ 0 + τ y / g , as follows:
VISCOSITY_MODEL( "Basic Bingham Law" ) {
    type                     = bingham
    bingham_viscosity        = 0.001
    bingham_yield_stress     = 10
Papanastasiou's unyielded stress region growth rate exponent modification limits the viscosity at low shear rates to μ = μ 0 + τ y M and provides for a smooth transition from the unyielded to the yielded stress regions. For example:
VISCOSITY_MODEL( "Bingham Law with Papanastasiou exponent" ) {
    type                           = bingham
    bingham_stress_growth_exponent = 1000
To add a power law model modification to the viscosity model:
VISCOSITY_MODEL( "Bingham Law with Papanastasiou exponent and power law" ) {
    type                           = bingham
    bingham_time_constant          = 1
    bingham_index                  = 0.75
The carreau type defines a third non-Newtonian viscosity model:
μ= μ ∞ +( μ 0 − μ ∞ ) (1+ (ηg) a ) (n−1)/a MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0JaeqiVd02aaSbaaSqaaiabg6HiLcqabaGccqGHRaWkcaGGOaGa eqiVd02aaSbaaSqaaiaaicdaaeqaaOGaeyOeI0IaeqiVd02aaSbaaS qaaiabg6HiLcqabaGccaGGPaGaaiikaiaaigdacqGHRaWkcaGGOaGa eq4TdGMaam4zaiaacMcadaahaaWcbeqaaiaadggaaaGccaGGPaWaaW baaSqabeaacaGGOaGaamOBaiabgkHiTiaaigdacaGGPaGaai4laiaa dggaaaaaaa@52F8@
where μ 0 is the viscosity at zero shear rate, given by carreau_zero_shear_viscosity; μ ∞ is the viscosity at infinite shear rate, given by carreau_infinite_shear_viscosity; η is the time constant, given by carreau_time_constant; n is the power index, given by carreau_index; a is the transition index, given by carreau_transition_index; and g is the square root of the second invariant of the strain rate tensor (see above). In this form this model is known as the Carreau-Yasuda model. If a = 2, then the classic Carreau model is recovered.
For example,
VISCOSITY_MODEL( "Carreau Model" ) {
    type                                = carreau
    carreau_zero_shear_viscosity        = 681.8
    carreau_infinite_shear_viscosity    = 0.17
    carreau_time_constant               = 31.7
    carreau_index                       = 0.11
    carreau_transition_index            = 2
The sutherland type defines a temperature dependent viscosity model according to the following equation:
μ= μ 0 ( T T 0 ) 3/2 T 0 +S T+S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0JaeqiVd02aaSbaaSqaaiaaicdaaeqaaOWaaeWaaeaadaWcaaqa aiaadsfaaeaacaWGubWaaSbaaSqaaiaaicdaaeqaaaaaaOGaayjkai aawMcaamaaCaaaleqabaWaaSGbaeaacaaIZaaabaGaaGOmaaaaaaGc daWcaaqaaiaadsfadaWgaaWcbaGaaGimaaqabaGccqGHRaWkcaWGtb aabaGaamivaiabgUcaRiaadofaaaaaaa@477F@
where μ 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd02aaS baaSqaaiaaicdaaeqaaaaa@3892@ is the sutherland_reference_viscosity at the specified sutherland_reference_temperature ( T 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaaIWaaabeaaaaa@37B5@ ), T MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaaaa@36CF@ is the model temperature and S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ is the sutherland_constant.
For example,
VISCOSITY_MODEL( "Sutherland Model" ) {
type = sutherland
sutherland_reference_viscosity = 1.716e-5
sutherland_reference_temperature = 273.0
sutherland_constant = 111
A ramped viscosity model is the same as the constant one, except that the viscosity is ramped down from 1000 times the viscosity value at time step one to the viscosity value at time step ten. For example,
VISCOSITY_MODEL( "ramped viscosity model" ) {
    type        = ramped
starts with a viscosity of 1.781 x 10-2 at time step one and reduces the viscosity until time step 10, at which time a viscosity of 1.781 x 10-5 is used.
Viscosity models of types piecewise_linear and cubic_spline may be used to define viscosity as a function of a single independent variable. For example,
VISCOSITY_MODEL( "curve fit viscosity model" ) {
    type                 = piecewise_linear
    curve_fit_values     = { 273, 1.72e-5 ;
                             323, 1.95e-5 ;
                             373, 2.17e-5 ;
                             423, 2.38e-5 ; }
    curve_fit_variable   = temperature
defines viscosity as a function of temperature. In this case, the problem must contain a temperature equation; see the EQUATION command. The curve_fit_values parameter is a two-column array corresponding to the independent variable and the viscosity values. The independent variable values must be in ascending order. The limit point values of the curve fit are used when curve_fit_variable falls outside of the curve fit limits.
The curve_fit_values data may be read from a file. For the above example, the curve fit values may be placed in a file, such as viscosity.fit:
273       1.72e-5
323       1.95e-5
373       2.17e-5
423       2.38e-5
and read by:
    curve_fit_values    = Read( "viscosity.fit" )
A viscosity of type user_function may be used to model more complex behaviors; the see AcuSolve User-Defined Functions Manual for a detailed description of user-defined functions.
For example, consider a simplified version of the non-Newtonian power law viscosity model discussed above. The input command may be given by:
VISCOSITY_MODEL( "UDF viscosity model" ) {
    type           = user_function
    user_function  = "usrViscosityExample"
    user_values    = { 9000,   # reference viscosity
                         12.5,   # time constant
                          0.48 }  # power index
where the user-defined function "usrViscosityExample" may be implemented as follows:
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrViscosityExample ) ;                                    /* function prototype               */
Void usrViscosityExample (
    UdfHd         udfHd,                                                  /* Opaque handle for accessing data */
	Real*         outVec,                                                 /* Output vector                    */
	Integer       nItems,                                                 /* Number of elements               */
	Integer       vecDim                                                  /* = 1                              */
    Integer       elem ;                                                  /* an element counter               */
    Real          exp ;                                                   /* exponent ( (index-1)/2 )         */
    Real          index ;                                                 /* power index                      */
    Real          invar2 ;                                                /* second invariant of strain rate  */
    Real          tConst ;                                                /* time constant                    */
    Real          tConst2 ;                                               /* scaling factor (tConst ^ 2)      */
    Real          visc0 ;                                                 /* reference viscosity              */
    Real*         gradV ;                                                 /* gradient of velocity             */
    Real*         u11 ;                                                   /* partial u1 / partial x1          */
    Real*         u12 ;                                                   /* partial u1 / partial x2          */
    Real*         u13 ;                                                   /* partial u1 / partial x3          */
    Real*         u21 ;                                                   /* partial u2 / partial x1          */
    Real*         u22 ;                                                   /* partial u2 / partial x2          */
    Real*         u23 ;                                                   /* partial u2 / partial x3          */
    Real*         u31 ;                                                   /* partial u3 / partial x1          */
    Real*         u32 ;                                                   /* partial u3 / partial x2          */
    Real*         u33 ;                                                   /* partial u3 / partial x3          */
    Real*         usrVals ;                                               /* user values                      */
udfCheckNumUsrVals( udfHd, 3 ) ;                                          /* check for error                  */
    usrVals      = udfGetUsrVals( udfHd ) ;                               /* get the user vals                */
    visc0        = usrVals[0] ;                                           /* reference visc.                  */
    tConst       = usrVals[1] ;                                           /* time constant                    */
    index        = usrVals[2] ;                                           /* index                            */
    tConst2      = tConst * tConst ;                                      /* for efficiency                   */
    exp          = (index - 1) / 2 ;                                      /* for efficiency                   */
    gradV        = udfGetElmData( udfHd, UDF_ELM_GRAD_VELOCITY ) ;        /* get the grad-vel.                */
    u11          = &gradV[0*nItems] ;                                     /* localize u11                     */
    u12          = &gradV[1*nItems] ;                                     /* localize u12                     */
    u13          = &gradV[2*nItems] ;                                     /* localize u13                     */
    u21          = &gradV[3*nItems] ;                                     /* localize u21                     */
    u22          = &gradV[4*nItems] ;                                     /* localize u22                     */
    u23          = &gradV[5*nItems] ;                                     /* localize u23                     */
    u31          = &gradV[6*nItems] ;                                     /* localize u31                     */
    u32          = &gradV[7*nItems] ;                                     /* localize u32                     */
    u33          = &gradV[8*nItems] ;                                     /* localize u33                     */
    for ( elem = 0 ; elem < nItems ; elem++ ) {
        invar2       = 2.
                     * ( u11[elem] * u11[elem]
                     + u22[elem] * u22[elem]
                     + u33[elem] * u33[elem]
                     + (u12[elem]+u21[elem]) * (u12[elem]+u21[elem])
                     + (u23[elem]+u32[elem]) * (u23[elem]+u32[elem])
                     + (u31[elem]+u13[elem]) * (u31[elem]+u13[elem]) ;
         outVec[elem] = visc0 ;
         if ( tConst2 * invar2 > ) {
             outVec[elem] = visc0 * pow( tConst2 * invar2, exp ) ;
} /* end of usrViscosityExample() */
The dimension of the returned viscosity vector, outVec, is the number of elements.
The multiplier_function parameter may be used to uniformly scale the viscosity values. The value of this parameter refers to the user-given name of a MULTIPLIER_FUNCTION command in the input file. For example, a ramped viscosity may be specified by:
VISCOSITY_MODEL( "similar to ramped viscosity model" ) {
    type                   = constant
    multiplier_function     = "ramped"
MULTIPLIER_FUNCTION( "ramped" ) {
    type                   = piecewise_log_linear
    curve_fit_values       = { 1, 1000 ; 10, 1 }
    curve_fit_variable     = time_step
In areas of turbulent flow the molecular viscosity μ is replaced by the total viscosity μ + μ t in the definition of the viscous stress tensor. The turbulent viscosity μ t is given by the turbulence model in use; see the EQUATION command for details.
