ACU-T: 3203 Heat Transfer Between Concentric Spheres – Discrete Ordinate Radiation Model
Prerequisites
This tutorial provides the instructions for setting up, solving, and viewing results for a steady state simulation of radiation heat transfer between concentric spheres using the Discrete Ordinates (DO) Radiation model. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
The problem to be addressed in this tutorial is shown schematically in Figure 1. In this problem, a DO radiation model is used to simulate the heat transfer due to radiation between concentric spheres. The inside surface of the inner and the outside surface of the outer sphere are both held at constant temperature while the gap between them radiates the heat from one sphere to the other.
The problem consists of a fluid region with arbitrary material properties between two concentric spheres with surfaces held at fixed temperature, as shown in the following figure, which is not drawn to scale. The radius of the outer sphere is 0.04 m and the radius of the inner sphere is 0.01 m. The inner surface of the inner sphere is defined to have a constant wall temperature at 300.0 K (26.85 ºC). The outer surface of the outer sphere is defined to have a constant wall temperature at 1300.0 K (1026.85 ºC). The fluid within the spheres is defined as a non-conducting material, allowing heat to transfer via radiation only.
The problem is solved as a steady state case to allow the heat transfer in the solid and fluid regions to reach an equilibrium.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T3203_DO_Rad.hm and click Open.
- Click .
Create a new directory named DO_radiation and navigate into this directory.
- Enter DO_radiation as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 4.
The Setup dialog opens. -
- Set Time marching to Steady.
- Set the Turbulence model to Laminar.
- Activate the Heat transfer checkbox.
Figure 5.
- Click the Solver controls setting.
Deactivate the Flow checkbox.
In this tutorial, you will only be solving for the temperature field.
Figure 6.
- Close the dialog and save the model.
Create Material Models
From the Flow ribbon, click the Material Library tool.
Figure 7.
The Material Library dialog opens. - Under Settings, click Fluid then click the My Materials tab.
Click
to create a new material.
- In the new dialog, rename the material to Radiating by clicking the name in the top-left corner.
Enter the following values for each of the material property tabs then close
the dialog.
- Density – 1000 kg/m3
- Specific Heat – 10000 J/kg-K
- Viscosity – 1e-5 kg/m-sec
- Conductivity – 1e-6 W/m-K
Figure 8.
- Click the Solid setting.
Repeat the above steps to create two material models
(Inner and Outer) using the
following parameters:
- Inner
- Conductivity – 2 W/m-K
- Outer
- Conductivity – 0.35 W/m-K
Assign Material Properties
Figure 9.
Select the outer solid and assign the Outer material
model from the microdialog.
Figure 10.
On the guide bar, click
to execute the command and remain in the
tool.
- In the Materials legend, right-click on Air and select Isolate.
- Select the outer solid and assign the Radiating material model to it.
- In the Materials legend, right-click on Air again and select Isolate.
- Select the remaining solid and assign the Inner material model to it.
to execute
- Save the model.
Assign the Flow Boundary Conditions
From the Flow ribbon, click the No Slip tool.
Figure 11.
- Select the two faces of the sphere then right-click and select Hide.
Select the two faces remaining in the modeling window.
In the microdialog, assign a
Temperature boundary condition at
300 K.
Figure 12.
- In the Boundaries legend, double-click on Wall and rename it to Inner.
tool.
- Press the A key to turn on the display of all surfaces.
- Select the two outer faces. In the microdialog, assign a Temperature boundary condition at 1300 K.
- In the Boundaries legend, double-click on Wall and rename it to Outer.
to execute
- Save the model.
Set Up Radiation
Select the Radiation Model
From the Radiation ribbon, Thermal Radiation tools, click the Physics tool.
Figure 13.
The Radiation Settings dialog opens. -
Activate the Thermal radiation checkbox and set the
Radiation model to Discrete Ordinate.
Figure 14.
- Set the Radiation quadrature to S4.
- Verify that the Default radiation surface diffused fraction is set to 1.
Define the Radiation Material Properties
Click the Surface Finish Library tool.
Figure 15.
The Surface finish library opens. -
Click
- In the table, double-click on Surface Finish, rename it to Inner, and the Emissivity to 0.5.
Similarly, create another Emissivity model named Outer
with an Emissivity of 0.8.
Figure 16.
From the Participating Media tools, click the
Model tool.
Figure 17.
The Participating media model library opens. -
Click
and create a model with the following properties.
Figure 18.
Assign the Participating Media Model
Assign tool.
Figure 19.
- In the modeling window, right-click and select
- In the microdialog, verify that the Air model is selected.
Click
on the guide bar.
- In the Participating Media legend, right-click on Air and select Isolate.
Assign the Emissivity Model
From the Thermal Radiation tools, click the
Surface Finish
tool.
Figure 20.
- Select the two outer surfaces.
- In the microdialog, select the Outer surface finish model.
Click
on the guide bar.
- In the Participating Media legend, right-click on Black Body and select Isolate.
- Select the two visible surfaces and assign the Inner surface finish model.
Click
on the guide bar.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 21.
The Meshing Operations dialog opens.Note: If the model has not been validated, you are prompted to create the simulation model before running the batch mesh. - Check that the Average element size is 0.0025 and the Mesh growth rate is 1.0.
Accept all other default parameters.
Figure 22.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
Run AcuSolve
Figure 23.
- Set the Parallel processing option to Intel MPI.
- Expand Default initial condition and set the Temperature to 300 K.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 24.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: While AcuSolve is running, right-click on the AcuSolve job in the Run Status dialog and select View Log File to monitor the solution process.
Post-Process the Results with HM-CFD Post
- Once the solution is completed, navigate to the Post ribbon.
- From the menu bar, click .
Select the AcuSolve log file in your problem
directory to load the results for post-processing.
The solid and all the surfaces are loaded in the Post Browser.
In the browser, click the icon beside Flow Boundaries to turn off the display
of all the surfaces.
Figure 25.
Click the Slice Planes tool.
Figure 26.
- Select the x-y plane in the modeling window.
In the slice plane microdialog, click
to
create the slice plane.
- In the display properties microdialog, set the display to Temperature and activate the Legend toggle.
Click
and set the Colormap Name to Rainbow
Uniform.
Figure 27.
Click
on the guide bar then press F
to fit the section cut to the screen.
Figure 28.
Summary
In this tutorial, you learned how to set up and solve a radiation heat transfer simulation using the Discrete Ordinates radiation model. You started by importing the HyperMesh CFD input database and then defined the flow and radiation setup. Then, you generated the mesh and submitted the AcuSolve simulation. Once the solution was computed, you created a contour plot of temperature distribution on a section cut using HyperMesh CFD Post.
