ACU-T: 4101 T-Junction Flow using the Eulerian Multiphase Model
Prerequisites
This tutorial provides the instructions for setting up and running a basic transient multiphase simulation using the Eulerian multiphase model. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T4101_TJunction.hm and click Open.
- Click .
Create a new directory named T_Junction and navigate into this directory.
- Enter T_Junction as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 4.
The Setup dialog opens. - Under the Physics models setting, select the Multiphase flow radio button.
- Change the Multifluid type to Eulerian.
Click the Eulerian material drop-down menu and select Material
Library from the list.
You can create new material models in the Material Library.
In the Material Library dialog, select Eulerian
Multiphase, switch to the My Material
tab, then click
to add a new material.
- In the microdialog, click on the top-left corner and change the name to WaterAirEul.
- Set the Carrier field to Water and the Disperse field to Air.
Set the diameter, drag model, and other parameters as shown in the image
below.
Figure 5.
- Close the material model microdialog and then close the Material Library dialog.
- In the Setup dialog, set the Eulerian Material to WaterAirEul.
- Set Time step size and Final time to 0.01 and 1, respectively. Select Spalart-Allmaras for the Turbulence model.
Set the gravity to 0, -9.81, 0 and the pressure scale to
Absolute.
Figure 6.
Click the Solver controls setting and set the Minimum
and Maximum stagger iterations to 2 and
4, respectively.
Figure 7.
- Close the dialog and save the model.
Assign Material Properties
Figure 8.
- Verify that WaterAirEul has been assigned as the material.
On the guide bar, click
to exit
the tool.
From the Flow ribbon, click the Constant tool.
Figure 9.
Click the inlet face highlighted in the figure below.
Figure 10.
- In the microdialog, activate Phasic inflow and then change the inflow velocity type to Normal.
- Enter a value of 1.5 and 1.6 m/s for the Normal velocity of the Carrier Field and Disperse Field, respectively.
Set the Volume fraction specification type to Value and
set the Carrier fluid volume fraction to 0.98.
Figure 11.
Click the Turbulence tab in the microdialog. Set the Turbulence input type to
Direct and the Eddy viscosity to
0.001.
Figure 12.
Note: When phasic inflow is active, Turbulence input type = Direct should be used. -
to execute
Click the Outlet tool.
Figure 13.
Select the face highlighted below and verify the settings in the microdialog.
Figure 14.
to execute the command and remain in the
tool.
With the Outlet tool still active, select the face highlighted below after
rotating the model. Then click
on the
guide bar.
Figure 15.
Click the Slip tool.
Figure 16.
Select the top and bottom faces highlighted below then click
on the
guide bar.
Figure 17.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 18.
Note: If the model has not been validated, you are prompted to create the simulation model before running the batch mesh. -
In the Meshing Operations dialog, check that the Average
Element size is set to 0.0025.
Figure 19.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
Define Nodal Outputs
From the Solution ribbon, click the Field tool.
Figure 20.
The Field Output dialog opens. - Check the box for Write Initial Conditions.
Set the time interval to 1.
Figure 21.
Run AcuSolve
Figure 22.
Expand Default initial conditions, uncheck
Pre-compute flow, and set the velocity values to
0. Uncheck Pre-compute
Turbulence.
Figure 23.
Click Run to launch AcuSolve.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: While AcuSolve is running, right-click on the AcuSolve job in the Run Status dialog and select View Log File to monitor the solution process.
Post-Process the Results with HM-CFD Post
- Once the solution is complete, right-click the AcuSolve run in the Run Status dialog and select Visualize results.
- Once the results are loaded in the Post ribbon, click the Top face of the view cube to orient to the xy-plane.
Click the Boundary Groups tool.
Figure 24.
- In the modeling window, select the top slip surface.
- In the microdialog, set the display variable to velocity.
- Activate the Legend toggle and set the legend limits to 0 and 2.5, respectively.
Click
and set the colormap properties as shown
below.
Figure 25.
Click
on the guide bar to create the velocity contour
plot.
Figure 26.
- In the Post Browser, right-click Boundary Group 7 and select Edit.
- In the microdialog, change the display variable to volume fraction: air and set the legend limits to 0 and 0.1.
Click
on the guide bar to create the volume fraction contour
plot.
Figure 27.
Summary
In this tutorial, you learned how to set up and solve a multiphase flow simulation using the Eulerian multiphase model available in AcuSolve using HyperMesh CFD. You started by importing the HyperMesh CFD input database and then defined the flow setup. Once the solution was computed, you created a contour plot of velocity and field volume fraction using HyperMesh CFD Post.
