Files in ACUSIM.DIR
ACUSIM.DIR is the primary data storage directory for results from a solution. ACUSIM.DIR contains various files that completely define the simulation, including results. The directory stores data in a variety of files, each corresponding to a different type of output. These files should not be managed manually.
File Grouping File Extension Description
Auxiliary Files .slv AcuPrep solver input
Basic .cli Replicated .echo file
.ddc Domain decomposition
.oqi Mask information
.top Solutions summary
.dat Domain connectivity
.osn Surface composition
Derived Quantity Output .odq
Nodal Output .out
Restart .rst
Time History .oth
