Altair SEAM 2024.1 Release Notes
Highlights
  • Support for different types of NCTs on both sides.
  • Optimization workflow.
New Features
Optimization Workflow
The Optimization workflow is a powerful and efficient end-to-end workflow for pre-processing, solving, and post-processing. The optimization defines the optimization setup for the selected analysis. Use this option to create design variables for subsystem parameters and Boit material parameters. Select options to create design responses, constraints, and objectives for the user-defined load cases before submitting the optimization. You can save the complete optimization setup in a CSV file for review and reuse. Use the new post-processing utility to post-processes the optimization results.
Enhancements
Post-processing
  • You can now graphically select a subsystem during contouring.
  • Performance improvement when reading the results file.
  • You can now view the sensitivity of the run.
Tools
The High Frequency profile supports the MM-TON-SEC unit system.
SEAM can now read and apply user-defined NCTs and layered NCTs on both sides of a structural subsystems,with any combination.
Resolved Issues
  • Auto connect in structural connection.
  • NCT update.
